SOLD: Tortenmann/Telenordia TT-3 Tremolo
domforrdomforr Frets: 326
edited March 2015 in FX £
Tortenmann TT-3 tremolo. Beautiful warm, organic sounds in mint condition with box. Can also double as a clean boost - push/pull switch deactivates tremolo. - £135 ppg  £125 delivered SOLD
  • domforrdomforr Frets: 326
    Pics now added.
    Bump
    Monday bump
  • I can't see any pics :(
    Strange - they seem to be showing fine for me?
    Does this one show?:
    Ah they do on my iPhone but not on my works computer. Never heard of that Trem. Are there any sound files somewhere?
    Yes, they're relatively rare, although used by Radiohead. Ryan Adams amongst others. There's some sound files on their website:
    http://www.tortenmann.de/product.php?id=tt-3.
    I can't find much else, but to my ears it's the best sounding tremolo I've ever played (includes Diamond, Demeter, Boss etc).
  • hotpickupshotpickups Frets: 1823
    edited February 2015
    Has to be powered by a power supply i.e. no battery etc? Whats the boost like? Does it get dirty as a clean boost etc? I am thinking about a tremolo and if it's boost is something like my Soul Food then I could have 2 in one pedal etc
    No you can power with either a battery or a power supply (uses 9-18v power). I've got a few of their pedals and I use a mix of power supply and batteries (for the treble booster which has reverse polarity).
    The boost is very nice and will certainly push it into a bit of dirt if required. Also adds a bit of the germanium warmth and grit to the sound that I love.
    Don't suppose you know the power consumption required etc?
    Can you see that? Just copied directly but seems to be showing for me.
    Should work with most standard power supplies. It can go up to 18v but I've generally just used 9v and it sounds great.
  • domforr said:
    Thanks, quite low draw then. I suppose the decibel boost will go to 30DB only if using an 18v supply. I'll check out those sound files when I get home tonight. I believe they've gone out of business but what is the difference to the TT-2 vs TT-3?
    Still in business as far as I'm aware, although they changed names from Telenordia to Tortenmann a few years ago. My mistake, it is a TT-3 not a TT-2! They've only ever had the TT-3 as far as I'm aware, my brain is just playing up.
    Ah that's probably what I read somewhere. I'll check out the sound files and let you know what I think etc
    Cool
    Bump
     Dispatch master now added.
