Boss GT-Pro Rack Preamp - Your Thoughts?
HarrySevenHarrySeven Frets: 8033
Anyone got experience of these?
Snog, Marry, Avoid?
Forum feedback thread.    |     G&B interview #1 & #2   |  https://www.instagram.com/_harry_seven_/
  • AVOID!!!!!!!
    My main reason for saying that is that you described it as a preamp.  Although Boss effects are always good, the preamps sims are worse that virtually every other available option.
    If it's cheap and you only want it for effects then go ahead but there are many, many better amp modellers.
  • More for the effects, actually - however, while on the subject of preamps...I actually like over-processed guitar (in a bad '80's style). :)
  • The thing is that it's not over-processed bad, it's just bad!
  • monquixotemonquixote Frets: 17702
    edited February 2015 tFB Trader
    AVOID!!!!!!!
    Wisdom.
    I had a GT-100 and though it was a brilliant FX processor it's amp sims were worse than anything else I've tried (Line6, Fender, Blackstar, Zoom,Yamaha)
  • Then avoid I will (unless super-cheap) :)
  • is it the cosm stuff responsible for those preamps?
    Like everyone else has said, boss do an awesome effect but the amp sim stuff sucks balls
  • I thought it was just me! I loved the functionality of the GT8, which is very similar in a floor based unit. But it sounded real uninspiring.
