where do you put your boost?
HootsmonHootsmon Frets: 15991
before or after your ODs?
...and pleeeeease don't say.. "in the fridge beside the Mars Bar"
tae be or not tae be
  • mike_lmike_l Frets: 5700
    Depends, clean volume boost, post dirt, gain boost pre-dirt.
    Example, using the amp for dirt
    Clean boost - MXR Microamp - in loop
    Gain boost,- Bad Monkey/SD-1 - into the front of the amp.
  • LewLew Frets: 1657
    The fridge doesn't get a look in. Seriously though on my rocket boots.
    I used to use an SHO first in line more as a buffer to make everything sound more "sparkly" and clear. I've also used it after a quiet OD pedal (Boss OD2) to raise the level without altering it's grit.
    One before, one after.
  • POT into EP booster.
  • HootsmonHootsmon Frets: 15991
    ^ thought on the EP booster...worth the dough?
  • ennspekennspek Frets: 1626
    Mars bar in the fridge? I've never heard the like!
  • thecolourboxthecolourbox Frets: 9886
    Surely the Mars bars go in the deep fryer eh hootsmon?
    soundcloud.com/thecolourbox-1
  • GavRichListGavRichList Frets: 7213
    Before. 3rd, in a chain of a billion
  • ICBMICBM Frets: 72664
    Stops them from melting. Ask Marianne Faithfull.
    Allegedly..
  • KebabkidKebabkid Frets: 3337
    edited March 2015
    Same as not_the_dj who somehow managed to pick up a LOL for that???? Compressor and low gain OD pedals first followed by an EP Boost into an OCD to push it and thicken things up and then a Catalinbread Serrano Picoso boost after the OCD but before my modulations and delays for a pure volume boost.
    I've always gone low to high in boosts... so pre gain to push a bit more grit
    However, some might rather a volume boost rather than a gain boost, so after gain
    I only ever use dirty/gain boosts really though, so might be different on 'textured' boosts such as the ep
  • BGGBGG Frets: 689
    I go guitar > koko boost > XTS precision overdrive > amp.
    I get a lovely clean boost from the koko, then if I'm using the XTS and kick the koko on it gives it a nice lift for solos.
    #thebatesmotelband
  • slateslate Frets: 89
    Before
  • ShmooShmoo Frets: 109
    Currently before
  • Adam_MDAdam_MD Frets: 3420
    I'm going pick up another spark mini soon to do exactly this.
  • hubobuloushubobulous Frets: 2352
    Koko - Shiba/Velvet - Badger
  • d8md8m Frets: 2434
    In my mouth!
    You could try the Mick Jagger / Marianne Faithful method with that   :D
  • dilbertdilbert Frets: 203
    Before the dirt.
