Here is a picture of my pedals thus far.
There will be a couple of additions - a second delay, probably a DSD2 or DD3 in the loop, maybe replace the dyna drive with an OD3 (although the strat sounds really great through the dyna drive set as it is... Tough call!) and there will be an FZ-2 at some point on there, too, and a compressor - almost certainly a Dyna/Ross comp type, maybe an xotic SP. Something squishy and colourful.
The qtron could be replaced by a DOD FX25, which would save a wee bit of space...
Anyway, what boards are out there that would be roughly the right size for this lot? I did have a cheap cheap board that was about half the size it needs to be, but it was a no name one... And I broke it.
So something tougher is good. As far as power goes, I'm happy with the power plant junior - to get something capable of powering the QTron would cost a lot, and I may replace this with the DOD anyway...
JM build | Pedalboard plans
I hope to replace the Qtron for something more reliable and tough, and I may replace the dyna drive, but it sounds really nice with my strat. I'll have to see how it is into a nice valve amp, though, as I know the od3 is very cool.
Basically, I should be able to estimate board size by replacing any missing pedals with what I'll replace them with anyway. Then add the ones I will be adding - dsd-2, fz-2, dod milkbox and a reverb of some kind, although I don't know much about them, I reckon the boss reverb is a sure bet for a decent Hall sound, or maybe the zoom ms70.
You should get the right sound for songs like 'Ain't no mountain high enough' with the Dyna/Ross.
