where do you put your boost?
  • I generally use one boost before my dirt to thicken up the dirt/clean boost a clean signal.
    After the dirt I use a TS type pedal to give a volume boost and more dirt/presence/balls.
  • CatthanCatthan Frets: 366
    edited March 2015
    I have an ep booster that I use in the loop of my MkV. Always on.
    More of a tone-shaping tool than a boost.
    What it also allows me to do is bring down the loop level so the amp works better with my flashback and then compensate with the ep which sits after the delay.
