I had a weird problem with batches of TAD EL84s.
They worked fine but when brand new would produce a low level "crackly/burbly" noise. Low level, never notice it on a stage but definitely in a quiet workshop. The noise subsided over period of a few hours soak testing, especially if blasted into a load box.
Not all samples crackled but those that didn't could often be induced to do so if given a flick from finger and thumb. This led me to suspect the cause was a microscopic piece of debris in the valve that eventually got "gettered"?
I suspect Paul you had a TAD with a rather larger than microscopic piece of ***t!
The issue seemed resolve itself after a couple of months.
Dave.
Bandcamp
Spotify, Apple et al
