PURGE III
PLEASE READ THE FOLLOWING
For those that don’t know, Cleggy and I build stompboxes. Over the years our respective stashes of them have got out of control. So we’ve decided to go through them, keep only 20 or so each, and put the rest in a central ‘demo’ stash for people to try. All the pedals in this listing are surplus duplicates from this re-organisation.
All the pedals run on a standard Boss style (centre ground, outer 9V DC) power supply. None of them have battery provision as we don’t use them.
Where pedals are described as clones that is within part tolerance and accuracy of the schematics. Where we have modified them from that I will detail it.
If you wish to see gut shots, they’re on my main site with the build reports for the pedals. Everything I’ve ever built is in there and there’s more detailed info on the pedals there also: http://stompage.juansolo.co.uk
Delivery in the UK will be 2nd class signed for and will be £5 (I’ve had to buy a tonne of boxes and bubble also so that’s in the P&P). For multiples, if I can get it in a small parcel and under the PO weight limit, It’ll still be £5. For anywhere outside the UK please contact for costs, but it’s usually around £10 or so.
Payment is preferably by bank transfer (if you’ve got online banking it’s usually down as Pay Another Person), or PayPal gift
There are 47 to go and I’ve taken pics of all of them in their current condition, so give the page to load. I’ve centralized everything on The Fretboard because this would be chaos to keep track of on multiple forums.
So it begins...
UPDATE
Everything must go. All remaining pedals prices dropped
Pic
MXR117 Flanger Clone
Condition – 4 – Decal has some odd colours going on (it was when my printer was being a bit of an arse), but otherwise excellent.
Cost - SOLD
Pic
OD820 Clone
Condition – 5 – Excellent
Cost - £40 - SOLD
Pic
ADA Flanger Clone
Condition – 4.5 – It’s etched so has a few light marks
Cost - £100 - SOLD
This one was made by LaceSensor on the Madbean forum. The one Cleggy made has ended up in the stash so mine has to go (we’re being brutal). This is a superb clone and worth every penny IMO.
Pic
Alice 1 Multi Effect
Condition – 4.5 – Near excellent, only marking it down because it’s old
Cost - £65 - SOLD
My first multi. I kept it for posterity, but the stash is too big to be sentimental now. It’s all vero inside, but still neat considering. It’s got an UglyFace with LFO, into a EA Tremolo, into a Rebote delay.
Pic
Baby Boob Tube
Cost - £65 - WITHDRAWN
Tube boost. Sounds great on the front of a single channel amp where it’ll behave sort of like another channel. Circuit is based on a bit of a Vox. But don’t assume it’ll make your amp sound Voxy because of that. It’s a quite powerful tube boost.
Pic
Black 65 clone
Cost - £55 - SOLD
http://juansolo.co.uk/misc/PurgeIII/bluemon.jpg
Blue Monster
Condition – 4 – Very faded decal
Cost - £45
This is a very unique dual channel OD/Distortion designed by Bengt Vallhagen. It’s a little noisy by nature. But has some great sounds.
http://juansolo.co.uk/misc/PurgeIII/boobtube.jpg
Boob Tube
Cost - £60
Mini version of the original. Built on Thomas’ board in a surprisingly small enclosure. Tube OD of awesomeness.
Pic
Discrete Cake
Condition – 4.5 – Weird reaction with the vinyl decal and the Envirotex. It’s a bit bubbly, but I quite liked the effect
Cost - £40 - SOLD
An interesting take on a Hotcake using a discrete op-amp. Has that flavor, but is a little bit different and cool. It was an experiment by Jason (Jubal81)
Pic
Clone Theory Clone
Cost - £50 - SOLD
It’s a bit noisy, but again, that’s the nature of the beast.
http://juansolo.co.uk/misc/PurgeIII/cyberbird.jpg
Tweed 57 clone
Cost - £50
http://juansolo.co.uk/misc/PurgeIII/dirty.jpg
? Lady clone
Condition – 3.5 – Decal isn’t so great (lines), bit of lifting.
Cost - £30
An approximation of a ? Lady using different transistors.
Pic
DLS clone
Condition – 4.5 – Flow marks in the Envirotex
Cost - £40 - SOLD
Pic
Tight Metal/’heavy’ Rock clone
Condition – 5ish – Mint with build errors (see below)
Cost - £70 - SOLD
Oh I ballsed this build up a bit Nothing I didn’t recover from, but you’ll notice the in/outs on the side are plugged and they’re actually on the top. Yeah, my fault. See the site for more details.
The pedal is a Tight Metal clone with a switchable Tight Rock. But because of the shared components, it’s more of a tight heavy rock. Still sounds cool as hell though. 1up/2up switches between them. Fight is tight
Pic
Echobase
Condition – 4 – Quite a bit of lacquer crazing
Cost - £40 - SOLD
Cool echo machine. Switch on the side is a kill-dry and it’s got tails. The downside to this is that if you kill dry and stomp it off, it goes silent. Probably shouldn’t have fitted it, but you can get some weird spacey shit out of it with it so I kinda had to have it. Leave the kill dry off and it works just fine. Obv, not a true bypass pedal this one.
Pic
Maestro Filter, Sample & Hold clone
Cost - £55 - SOLD
Great filter, or you can get your Zappa on with the S&H
http://juansolo.co.uk/misc/PurgeIII/fu.jpg
Modded Electra Distortion
Cost - £35
Basically a cut down Les Lius clone
Pic
Half a Double Sound Fuzz
Condition – 4 – Paint and lacquer finish, some chips in the paint
Cost - £35 - SOLD
Pic
Jon Patton’s Harmonic Tremolo
Cost - £45 - SOLD
There’s a trimmer inside with wave on it. Should probably have been a knob, but you can adjust that to taste (as I have done).
Pic
Hydra Prototype (Dual OD)
Cost - £60 - SOLD
Pic
Causality 4 Phaser
Condition – 2.5 – Scruffy as hell, probably a mess inside too
Cost - £25 - SOLD
All glory to the Hypnotoad!
Winks at you when off, goes full hypno when on. Yeah, a lot about this one is a bit iffy, but it’s still cool as hell.
Pic
Modded Dr Boogey
Condition – 3 – Scruffy, fair few paint chips
Cost - £35 - SOLD
Modded our way, makes it a lot more versatile.
http://juansolo.co.uk/misc/PurgeIII/mecha.jpg
Tourbillon Phaser
Cost - £35
Mad/unique optical phaser. Sounds quite vocal on some setting, doesn’t work at all on others. Get it in it’s sweet spot though and it’s awesome.
Pic
‘Mini’ Doppelganger clone(ish)
Condition – 4.5 – Weird discolouration on the right hand side (see pic).
Cost - £80 - SOLD
This is a smaller Doppelganger. It doesn’t have the expression jacks, but is otherwise full featured. It’s got different depth pots and LDRs that make it sound a little different to standard because we preferred it this way.
Pic
Reezafratzitz clone
Cost - £55 - SOLD
A little noisy. Again, it’s the nature of the beast.
http://juansolo.co.uk/misc/PurgeIII/mood.jpg
Moodring (delayed reverb)
Condition – 5 – Excellent. Though the pic does lack definition.
Cost - £55
Pic
Multiplex
Conditition – 4.5 – Decal faded quite badly/hard to read
Cost - £55 - SOLD
Modded with deep blue style filtering and the stretchy tape function is more sensitive than standard.
Pic
Murder One Amplifier
Condition – 4 – Very good
Cost - £65 - SOLD
Tiny guitar amp. Maybe 1/2 a watt or less. This one is the only thing on the list that needs a 12v power supply. Same deal with the polarity though (centre ground). Built by Rick Holt, not one of mine.
http://juansolo.co.uk/misc/PurgeIII/mutron.jpg
Mutron V clone
Condition – 4.5 – Some flow marks in the Envirotex
Cost - £45
Pic
P19 clone
Condition – 4.5 – Very good
Cost - £40 - SOLD
Pic
Phase 45 clone
Cost - £40 - SOLD
Pic
’71 Triangle
Cost - £40 - SOLD
Pic
Prom Girl
Condition – 4 – Decal very faded, lacquer crazed to hell
Cost - £35 - SOLD
Dirty valve distortion.
Pic
Quadravibe
Cost - £40 - SOLD
My favourite tremolo by far
Pic
Modded Rust Driver clone
Cost - £40 - SOLD
Pic
Lunar Module and Screwdriver clones
Condition – 3.5 – Scruffy as hell inside, couple of chips outside
Cost - £35 - SOLD
Pic
Ultra Stoner mk1
Cost - £45 - SOLD
Pic
Tenebrion Reverb (medium brick)
Cost - £50 - SOLD
Pic
Expandora clone
Cost - £40 - SOLD
Pic
Modded Timmy clone
Condition – 5+ – Brand new build
Cost - £60 - SOLD
Pic
Trivibe
Condition – 3.5 – Crazed lacquer, a bit scruffy
Cost - £35 - SOLD
Pic
Tusk (Klone) Prototype
Condition – 5 – As new
Cost - £65 - SOLD
Pic
Univibe clone
Condition – 5 – Excellent (rate pot works backwards)
Cost - £55 - SOLD
Pic
Merlin’s Spark Gap OD
Condition – 2.5 – Crazed lacquer, chips, no tube guards (though spare tubes)
Cost - £35m - SOLD
Pic
Duovibe (throbby optical tremolo/vibrato)
Cost - £45 - SOLD
Pic
ZenDrive clone
Condition – 3.5 – Couple of chips, labels obscured
Cost - £35 - SOLD
