Two amp set up...i need education!
samzadgansamzadgan Frets: 1471
So, recently the drummer and the other guitarist decided to leave the band due to "creative differences!"
as a result the bassist and i have decided to be a 2 piece with him on the drums and me on guitar. But, being that we play doom metal, i'm going to need some help on the amp side, and i know a lot of bands in the genre use two amp set up...and my case i would use one guitar amp and one bass amp to fill out the sound. I would run the guitar amp with all my pedals, and the bass amp i would run it relatively clean - maybe a little fuzz.
but when i comes to switchers and other devices that facilitate this type of set up i am completely lost and don't really know what to look for, whats good what rubbish etc...so any advice would be greatly appreciated.
  • randomhandclapsrandomhandclaps Frets: 20521
    edited October 2013
    Sorry Sam I might be missing something but why would playing through a guitar and a bass amp fill out your sound better than two guitar amps?  Some famous bass players used a guitar amp and bass amp setup with the purpose of the guitar amp to add presence.  I could only see the bass adding to overly weighty low end congestion.  It's not adding lower octave content.
    "adding to overly weighty low end congestion"
    that's actually not a bad thing in the kind of music we play
  • A bass amp isn't much different in tone from a guitar amp. Look at the fender bassman :)
    They're just very clean, and quite often, don't sound good. If you're playing doomy music, I'd suggest a pair of guitar amps, one at high gain, one at lower with an octave pedal in front giving you a lower octave, like a pog. The high gain could be an orange or a peavey 6505 (my fave). Just keep the gain below 7, it's got quite a lot, and you won't want to lose definition.
    For the cleaner amp, it might make sense to use a bigger speaker. A peavey delta blues is a classic 30 with a 15 inch driver, which should help those octave down notes maintain some kind of bassiness and not turn into detuned mids.
    The alternative is to run the octave down into a bass amp, which would work great too probably.
    If you want to sound massive, get a stereo chorus pedal. This will add a bit of swirl to the sound (don't turn it up, you'll get sea sick!) and act as a way of splitting your signal. This is all assuming you have a budget that can accommodate - I know I wouldn't!
  • vizviz Frets: 10762
    The traditional method is
    guitar > effects that you want each amp to enjoy
    effects out > amp 1 input
    amp 1 send > some sort of pedal or rack that splits, for example a digital delay, stereo chorus, etc
    outputs from that pedal > other effects that you want on either channel (not compulsory)
    outputs from those pedals > amp 1's and amp 2's return sockets.
    This arrangement will however cause a groundloop hum because of the (possibly) different potentials in each amp causing residual mains current to flow through the signal chain, so you will probably need to insert a signal isolator (eg an Ebtech hum eliminator) in the signal path of one of the two signals after the splitter. They're 40 quid from ebay.
    DO NOT USE A GROUND LIFT PLUG TO UNEARTH ONE OF THE AMPS. Your burning body will cause damage to your house and your insurance won't cover it.
  • steamabacussteamabacus Frets: 1276
    edited October 2013
    Cheaper / (probably) better at Orchid.
    thanks guys...
    i just came upon this Lehle Dual pedal...about £200...so quite pricey, given i will need to buy either a bass amp head and cab...or after ready @ThePrettyDamned post, a guitar amp head & Cab.
    http://lehle.com/EN/Lehle-Little-Dual
  • Paul_CPaul_C Frets: 7913
    years ago I used an Ibanez Stereo chorus to split the signal into an H||H Studio 100 and a Marshall valve combo.
  • JohnPerryJohnPerry Frets: 1629
    Lehle switchers are the best IMHO. And you can often find them at half that on eBaY. The Voodoo Lab Amp Selector is also brilliant and does 4 amps (officially twice as good as two amps). None of these will give you ground loop problems.
    Just get a new drummer or bassist who isn't a dick???
    Thanks, but he's after realistic options!!! ;)
    :-j
    Indeed!!!
  • ICBMICBM Frets: 72944
  • Sam, I think what ICBM is saying is that you're gonna need a couple of pairs or denim shorts.
  • ToneControlToneControl Frets: 12069
    I'm assuming you can't get your size in hot pants, but can actually play guitar
    Why not get a set of bass pedals? A bit fiddly, but would achieve better results if you practice, they wouldn't be able to sell them if no one could use them, so it might be worth a try
    I think they're pretty difficult to use standing up - at least the only time I tried they were, although I'm not renowned for my foot/balance coordination :) - so you might end up looking a bit 70s Genesis/Yes... but it might work.
    I was just being a bit funny with Hot Pants Girl. Her style is way more Jack White than anything... it was really just to show the amps she uses - a Bassman and a Hotrod Deluxe. Gets a pretty big sound with just a Mustang and a couple of dirt pedals, but it's hardly Doom.
    Actually the "Bassman" - that version - is a nearly useless bass amp. If you want real bottom end in the sound, I'd use an actual modern bass amp for the low-end, probably with 15" speakers rather than 10s as they tend to be a bit more 'growly'.
  • Would the signal chain be:
    Guitar - stereo splitter - (a) distortion - amp
    (b) pog - distortion - bass amp
    ? No idea how splitters or stereo effects pedals really work, but having a stereo chorus would make things massive...
    @ICBM thanks for the vid, but i think i have better legs than her! But the bassman got me thinking...like you say the second amp could be a bassman with a 2x15 cab and an octave pedal.
    So looking at chain...i would probably have something like this:
    Guitar > tuner > compressor> switcher pedal > then that goes 2 ways:
    1. Dirt pedals> noise gate > mod effects > guitar amp
    2. Octave/fuzz pedal > bassman amp
    This is becoming quite an expensive idea!
  • IvisonGuitarsIvisonGuitars Frets: 6842
    I just picked up a used Lehle Dual for under half retail. It's a stunning piece of kit, bomb proof and has a transformer on each output which eliminates the ground loop hum problem completely.
    If you are seriously looking to use a dual amp set up full time, in my opinion, you shouldn't scrimp on the switched/signal splitter part and go for the best you can afford. It'll save you major hassle & give you hum free gigs for years :-)
    http://www.ivisonguitars.com
    (formerly miserneil)
    Yes, a Bassman *head* and a 15" or 2x15" cab would be an excellent choice - they handle the low frequencies properly but still sound 'guitary' enough. Possibly the best-sounding plain amp I ever had was my much-missed '64 BF Bassman.
    You can pick up fairly low-powered 2x15"s very cheaply - they're big (though not always that heavy) and modern bass players don't want them unless they can handle at least 300W.
    I also wouldn't rule out an old-school solid-state bass amp - something like a Peavey Centurion - for the same reason, modern bass players don't want to know about any 100W bass head which sounds like a giant fuzz pedal... but it may be the very thing you need.
