I've wanted a Les Paul since I started playing nearly 20 years ago. I thought the urge had passed when I got my PRS SE 245 and loaded it with some of Oil City's finest. However when I spotted this on Thomann I couldn't resist. Okay, it's not a standard but the lack of figured top, binding etc doesn't bother me.
https://dl.dropboxusercontent.com/u/5256888/2015-05-31 10.06.18.jpgIt's a Les Paul Future Tribute. Thomann have them at ~£500 but this one was a B-stock item which was at ~£460. I've been over it thoroughly and I can only spot one issue and it took me a good while to realise what the actual issue was
https://dl.dropboxusercontent.com/u/5256888/2015-05-31 10.06.37.jpgClearly the bridge volume knob is sitting a little proud. On closer inspection the knob slightly different to the others so I'm guessing the original knob was lost at some point and this was the closest they could find to replace it. I'll change it at some point but it's not a major concern at the moment.
I'm sure most will have noticed the tuners.
https://dl.dropboxusercontent.com/u/5256888/2015-05-31 10.07.11.jpgI was almost certain that I'd be swapping out the Steinberger tuners but having changed the strings I actually really like them. The string change was so much easier and the tuners are smooth and accurate. Only time will tell if I can get along with the aesthetic side of things.
Unfortunately I've not had chance to plug it in yet but it's well setup (might need a tweak now it's got 11s on it rather than the elastic bands it shipped with). After everything I'd heard about Gibson quality control I was worried about buying blind but I'm happy with the way it plays. The neck is wider and thinner than I'm used to but it's comfortable. It's a 60s asymmetrical profile which also worried me as I'd read negative comments about them but I'm starting to think I can get on with most necks.
A lot of guitar for the money
Did it come with a hard case?
@RedRabbit, you've got a great looking guitar there.
In fairness the gigbag isn't too bad - nicely padded but still not a patch on the PRS gigbags. I'm glad I ordered the case even if they did send the wrong one. Rather than a nice plain brown leather case I got the crocodile effect leather instead. I'm not hugely bother but but it's a bit gaudy.
Had a chance to play through the gig rig (Jet City JCA22H, 2 x V30s and pedal board) and put it up against the PRS SE. The difference isn't huge but then I didn't expect it to be as Ash's pickup have made the PRS a great sounding guitar. Not sure which sounds better but I think the Les Paul will sound better in a band mix as it's bit brighter with tighter bass and just has something more to it (I'm desperately trying to avoid calling the sound more 3D). I guess it's a bit more aggressive than the PRS.
Still need to raise the action a bit more on the treble side as a few bends on the high E were slipping under my fingers but other than that I'm one happy camper.
