I think the 25th Anniversary Mira pre-dated the "Pattern" neck profiles, it had the Regular (aka Standard) profile and was the only Mira (apart from the Mira X and now the S2 models) with a 22 fret neck. It also had a 24.5" scale.
The original Mira had 24 frets, 25" scale and either a Wide Thin or Regular neck.
The Regular's a little narrower at the nut than the Wide Thin but a little thicker front to back. It's not a big neck though, I don't think you'd notice a massive difference from the Wide Thin.
I have a 25th Anniversary Mira. I would not describe it as a baseball bat, it's no thicker than some of the wide/thin necks I've owned in the past. My Teles 'U' shaped neck is noticeably thicker.
The 25th Anniversary does indeed have the 'Standard' neck carve. You're also correct about the number of frets and scale length. It also has P90 pickups, Seymour Duncans I believe.Ask mods to remove as i can't figure out how to delete unwanted comments
Again sorry all
Odd.
@Philly_Q What did you think of the Korina one? If funds improve there are a couple of Custom 24 Korina's around that I'd be tempted by.
Although I also now for some reason want a Suhr Modern Frost. Attention span must be shorter than I thought.
