I want one of these
DrBobDrBob Frets: 3012
http://www.soundsgreatmusic.com/products/Hotone-Liftup-Booster.html
For no other reason that I get an attack of the cutes whenever i look at it..
  • ddloopingddlooping Frets: 325
    It is indeed very cute, in a little robot head kind of way. :D
  • EricTheWearyEricTheWeary Frets: 16331
    Sweet.
    Very tempted by the delay. Just cause...
  • Dave_McDave_Mc Frets: 2389
    I'm guessing they wanted the brandname to sound like "hot tone", but every time i see it i can't help but see "ho tone". Which isn't quite so good.
  • BidleyBidley Frets: 2950
    I keep seeing "Hot One"
  • IanSavageIanSavage Frets: 1319
    Would have been perfect for those plastic Danelectro pedals a couple of years back though; cheap, nasty and liable to crack if you abused them, but most of the time got the job done.
  • Si_Si_ Frets: 384
    Some of them sound good..
    That was annoying yet reasonably informative. That delay really does seem to be good.
  • Si_Si_ Frets: 384
    Agreed on all counts.. the delay sounds great for the price.
  • digitalscreamdigitalscream Frets: 27034
    edited November 2013
    As with all cheap delays, though, it seems that the maximum delay time is only about 400ms. Pfffft.
    The other problem I see with these is that they're too small. I foresee problems hitting the button on a dark stage, with that bar right behind the switch - you can't just stomp on it, you've got to daintily tap it with your toe. I can't see any situation where that's a good thing.
    <space for hire>
  • dindudedindude Frets: 8565
  • dindude;72023" said:
    purple wind - curiously enough what I have this morning after a lentil based meal last night.
    I thought it was an undiscoverd Hendrix track.
  • DannyPDannyP Frets: 1690
    I thought the idea of the bar was that it's higher than the knobs but lower than bottom of the switch's travel, so you can just stomp on the whole thing with impunity?
  • Not sure about that:
    I guess that might work if you're not wearing shoes with particularly stiff soles. I'd have to try one to make sure...
    <space for hire>
  • Yeh, you would have to stomp with your toes and not the ball of your foot. Now trying to think what I normally do... 8-}
    Ah. Boo. :(
