Amaj7 to B - which scales would you use?
Just wondering how other people would approach this progression, as in what scales/notes they would choose - and why.  It's just two bars on each chord.  The first chord is A major 7 and the second is a simple B major.
The responses might help me work out whether there are options are ideas I'm missing :)
Trading feedback info here
My band, Red For Dissent
«13
  • I would use F# Dorian, which is the same as A lydian.  If I really wanted to bring out the Lydian sound I would focus on G# minor pentatonic.
  • octatonicoctatonic Frets: 33904
    You could also treat that as a IV V, but that would imply the B as a B7.
    As Lydian is the IV, isn't that theoretically the same as how @bingefeller would approach it?
  • vizviz Frets: 10762
    edited October 2015
    Two major chords a tone apart are very often IV and V, especially as the A is an A major7, consistent with Lydian. But it could also the VI and VII of C# minor (still lydian and mixo, like all along the watchtower), ie, playing c# aeolian works throughout the sequence
    Of course. Doh.
    I use C# aeolian for this. I'm just trapped in the relative approach to modes and most comfortable in aeolian or ionian, and it pretty much feels like cheating, or lazy.
  • BarneyBarney Frets: 619
    i like keeping things simple i would use Emaj.. but add other stuff in along the way :)
  • I made a backing track of Amaj7 to B and played over it
    Did you use a specific scale/mode/pattern?
  • Ah, F# dorian!
    Some lush stuff there old bean.
  • This is the track I was referring to:
    https://m.soundcloud.com/nosoapnoradio/smile-on-my-face
    Pretty much improvised throughout. I intend to actually write a proper intro piece, hence the question.
    In a sense but bingefeller was being prescriptive regarding what scale to play.
    If you consider the Amaj7 to be a IV chord there are many, many more scales you could use, other than just lydian.
    My point was by thinking of it as a IV V7 you have all sorts of substitutions you could use, rather just approaching it diatonically.
  • Is there a guide to substitutions you would recommend?
    edited October 2015
    @imalrightjack when I was playing over it I was thinking about F# Dorian, A triad, B triad, Emaj7 arpeggio and I think I used a lick in G# minor pentatonic.
    I was focussing a lot on the A and B triad pair and anytime I played the Emaj7 arpeggio it was over the B chord.
    Using the B triad over the A maj7 will bring out the lydian sound.
    edited October 2015
    Sure- it is a bit of a pandora's box- it is better to approach it from the perspective of what is the chord doing, rather than 'what scale do I play here?'
    You could treat the V chord as a ii V I, so instead of playing B major you play F#m, B7, Emaj7.
    The IV chord you could look at as a I chord of a ii V I, so instead of playing A Major you play Bm7, E7, Amaj7.
    You could use a tritone subs on either the B7, or the E7, which is itself a ii V I sub.
    You could you an augmented on the 5th scale degree (so a flat III+) for any of the dominants.
    You could flatten any V chord by one semitone.
    Get the Levine Jazz theory book.
  • I actually own it. I felt rather overwhelmed quite quickly. Must try again!
    Ok, cool- it is all in there.
    Yes, it can be overwhelming- approach it one idea at a time.
  • RolandRoland Frets: 8839
    What impact are you trying to achieve?  To emphasise the chord changes you could use A and B major over the two chords.  A major and B mixolydian would have a similar impact, but provide greater continuity because there is one less difference between the two scales.  There's a nice chromatic note sequence between the two: A Ab A Bb B.  At the other extreme the F# minor scale minimises the change between the A maj7 and B chords.
  • Ditto regarding the two major chords one tone apart signalling Emaj as root scale.
    If I knew in advance I'd play something diatonic but if not I might do Amaj or A lydian or A mixolydian over the Amaj7 and then the same but in B over the B. If anything sounded pants I'd pick up on it and change next time through!
  • frankusfrankus Frets: 4719
    First thing I'd do is work out if the maj7 sounded wrong for either of them. If so was one or both a dominant chord.
