Drums for Reaper?
Hi folks,
I recently upgraded to windows 10 and subsequently some of my software is no longer supported, its older versions.
I used to run ez drummer into ableton lite for recording.
I have now gone over to Reaper, it does not seem to have any drum sounds? Can anyone recommend some good drum software that works well with reaper?
Thanks
  • i use bfd
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • Why not continue using EZDrummer? It works fine in Reaper and Windows 10.
    <space for hire>
  • JD50JD50 Frets: 662
    I'd have to purchase it again as my version is about 5 years old and not supported for windows 10.
    I just wondered if anything better or cheaper had come out in the last few years or if perhaps there was a drum sequencer/machine in Reaper I had not located.
    I'm pretty sure there's a 64-bit patch version for the original EZDrummer which will make it work on Win10 - I believe that started with 1.3.0.
    <space for hire>
    I searched the toontrack site and found nothing for the original ezdrummer lite just a patch for the version 2.
    Ahhh...you didn't specify EZDrummer Lite ;)
    However, there is a 64-bit installer for that somewhere - I think you have to login to your Toontrack account to get downloads now.
    Funnily enough, EZDrummer Lite (and the full original version) works perfectly under Linux :D
    <space for hire>
  • markvmarkv Frets: 460
    PowerDrumKit is free, albeit very simple (which actually suits me) and works fine in Reaperhttp://www.powerdrumkit.com/
    markv;983971" said:
    PowerDrumKit is free, albeit very simple (which actually suits me) and works fine in Reaper: http://www.powerdrumkit.com/
    Thanks for the heads up that looks great. Don't suppose you.know of a good electronic sound drum program to?
  • rprrpr Frets: 310
    Thers a drum template for Reaper available here-http://stash.reaper.fm/v/328/ReaDrums.RTrackTemplate - it's based on the inbuilt sampler and uses the MIDi grid for programming.
    Drumatics - a non sample based electronic drum synth- has been round for a while- so I'm not not sure about Win 10- but worth a free download- here   http://www.vst4you.com/pages/vst instruments/drumatic_3.html
    Thanks @rpr, that template is a useful shortcut and Drumatics works like a charm on Win10
