Crack in the neck.. worth a punt?
equalsqlequalsql Frets: 6111
edited June 2017 in Bass
This Sandberg bass on Ebay, not far from where I am. Priced low cos of a crack in the neck.
http://www.ebay.co.uk/itm/Sandberg-Custom-shop-California-5-Bass-Guitar/152574095109?_trksid=p2045573.c100033.m2042&_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=43782&meid=c62df253d2a44a99881268f7ed966e68&pid=100033&rk=1&rkt=8&sd=152574095109
I'm after a good 5 string bass and wondered if this might be worth the risk?
Any luthiers out there got an opinion?
  • gusman2xgusman2x Frets: 921
    I'd say so. Won't cost much to get fixed (or DIY if you fancy).
    In fact, having an Ibanez neck crack fixed next week. And it's a gazillion times worse.
    http://i372.photobucket.com/albums/oo168/gusman2x/RG550DY/A7ADA1D1-8710-42F5-97C1-40465B2C3879_zpsqhp8lvsl.jpg
  • ICBMICBM Frets: 72336
    The real problem with that is that it's so fine a crack that actually getting glue into it is the difficulty. It can be done with very thin superglue/cyanoacrylate usually - you'll need to accept bit of finish damage that will need rubbing back, but otherwise it should be straightforward.
  • prowlaprowla Frets: 4921
    It seems OK to me.
  • JezWyndJezWynd Frets: 6060
    edited June 2017
    Does it need fixing? I'd live with it as it is, it doesn't seem to affect the structure. Nice bass.
    edit. I'm not a luthier.
    Worst that could happen is it gets worse, which would ironically make it an easier fix (if it opened up a bit)
    Go for it. If it's affecting play then you are probly gonna have to sink a bit more in to fix, but it would still be a reasonable bargain.
  • ecc83ecc83 Frets: 1633
    Strictly speaking the split is only in the head, not the neck. As IC says, tricky getting glue in there and in fact I would bet a professional repair would involve cutting slots along the splits and fitting slivers of a similar wood.
    Dave.
  • FunkfingersFunkfingers Frets: 14426
    edited June 2017
    It's your money. Ultimately, only you can assess the risk.
    If you want to play safe, buy my Warwick Streamer Pro Stage 1.
