Feline Guitars Lion Cub SC & DC thread : WAY COOL JUNIOR*
  • martinwmartinw Frets: 2149
    Drooling.
  • FelineGuitarsFelineGuitars Frets: 11594
    martinw said:
    Looking good! Colour me excited :)
    Progress being made....
    The masking tape with "NO" written on it was to remind me that this is having a REAR mounted strap button only
  • Philly_QPhilly_Q Frets: 22795
    I was wondering what that said!  I agree with Martin's choice.
    Here is the second completed one belonging to John Gallop - whose original 1959 Gibson LP Junior DC we used as the template for these. This has a full gloss paint finish and looks rather shiny.
  • Very very nice.
    No Darling....I've had that ages.
    Just wondering why you set the fretboard deeper into the body than a Gibson? On a 59 Junior the fretboard ends at the body join.
    It may make for a slightly stronger joint but mainly it makes the pickguard much neater and top fret access isn't hindered any.
  • armitaanarmitaan Frets: 379
    Along with the iguana V some seriously good looking guitars
  • John_AJohn_A Frets: 3775
    My bank balance really wishes I hadn't looked at this thread! Some serious thinking to do
    @Martinw from MJW Amps' Lion Cub DC is coming along nicely
    Next we'll have to strip , sand , stain and oil her
    Looking forward to this! :)
  • strtdvstrtdv Frets: 2438
    @FelineGuitars would it be possible to get one of these made with a second P90 (soapbar rather than dogear)? Roughly how much would would one be in gloss?
    Technically you can but there is a big risk of it weakening the neck joint as you are taking a LOT of wood out just where it is needed most.
    Doublecut deluxes are often seen broken  - the singlecut version is much stronger.
    Actually to follow on ...obviosly it can be done - as there are Gibson LP Deluxe Doublecuts (and SGs too) and the PRS heel is a workaround on this issue too. The neck pickup is often moved back from the end of the fingerboard to allow more strength or the neck is set further into the body in the case of the PRS
  • GuitarMonkeyGuitarMonkey Frets: 1883
    And the 2015 Les Paul Specials had a completely different neck joint.
    edited March 2016 tFB Trader
    Oh yes i've seen that
    More progress on MJW guitar and another which will be available to buy
    Stain coats have been applied and awaiting oil finishing
    This one is for @Martinw
    And this is the one that will be available to buy
  • BlacksheepBlacksheep Frets: 293
    The DC Specials Gibson made between 58 and late 59 are notorious for their instability and neck joint breakages.
  • IvisonGuitarsIvisonGuitars Frets: 6838
    Although in late '59 onwards, the DC's neck pickup was moved 1/2" towards the bridge making the neck joint much stronger.
    http://www.ivisonguitars.com
    (formerly miserneil)
  • GadgieGadgie Frets: 96
    So how much is one of these?
