Haven't yet adjusted the action, but the buzz remains. I don't really want the action higher, that's the problem though.
Maybe the neck is the problem.
I could try and take a photo of the neck, does this place allow pictures to be added?
Normally though any problems with the neck will be too subtle to be diagnoseable through photos.
Also, simply straightening the neck will not alleviate any issues with buzzing on its own, but what it does do is allow you to raise the height of the bridge more to achieve the same 12th fret action, and that should help with the buzzing higher up the neck.
So, if you haven't adjusted the bridge after lowering the relief, then it would be expected that your buzz will remain unchanged, and possibly get even worse. The two adjustments go hand in hand so just doing the relief will not solve the problem.
However, from everything you have said, it does sound like you have a neck that has inherent problems that will prevent you from achieving an action that is as low as you'd like it to be. I think you may need to make some compromises in terms of string buzz and string action. In my experience with guitars, all but the highest quality instruments will require some kind of compromise in their set up, if you demand a low action. You may simply be expecting too much out of your guitar.
Keep your relief at the amount suggested and leave it there, then keep raising the action at the bridge until the buzz goes away. Hopefully at some point it will.
Then it will be a matter of finding the right balance between lower string action and more buzz.
Incidentally, on one occasion I had a low E buzz on a guitar that would not go away. It happened just after I put a new set of Ernie Ball strings on. Tried everything to get rid of it to no avail. Eventually I restrung it again with a set of D'Addarios of the same string gauge and hey presto, the string buzz disappeared. Not saying that's the issue but stranger things have happened...
The chap in the shop i spoke to said that it should be possible to remove buzz entirely, of course that assumes idea conditions and components.
It's not unplayable. Perhaps it's just a question of getting used to it. IN fact the point about new strings (which these are, though I've no idea what brand or even guage they are) is well taken, i've experienced the same thing. I won't change them until i need to since bass strings cost the earth (a local shop used to sell a cheap brand they were idea for playing at home but no longer).
Thanks for the help, I think we've reached the best I can do. I will try and post a picture later, if anyone's interested.
http://i347.photobucket.com/albums/p469/ghostwhistler/20160808_130620_zpsexkit0jt.jpg
Oh and please do post a pic, and check back often. We need more fret-bass-ers around here!
I posted a pic above. The guitar is a Cort Action DLX. THe finish is quite nice, and it's disarmingly light!
but the EMG and Delano's I use have really low string pull.
In your pic it looks like they will be almost touching.
Regardless of the exact measurement, in my experience they - the neck one especially - are far too high.
It may make no difference to the buzzing problem, but at the very least it will make it difficult to get a good balance between the pickups.
HOwever, the buzz happens when i'm not plugged in, so I don't see how the pickup can be at fault.
The action on the E string is a shade higher than the rest. The A can't really go any lower without more buzz but is about 3mm. The E is a shade higher, nearing 4mm. This is obviously not idea according to those Fender specs, but without increasing the buzz on the E to the point i can't hear the notes on frets 4 5 10 and 11 (in particular) there's nothing i can do.
I think i've done the best I can. The neck could probably stand to be a touch tighter as well, just a touch. But getting an exact measurement is tough. I don't want to endlessly twist the rod of course.
Maybe it is the strings, but i'm not going to change them until they really need changing.
I like the pickups a little closer because plucking is easier. Not too close, but not so far that your anchoring your thumb way out. I have to say i've not noticed any major tone problems as a result, although my amp is a crappy inherited guitar practice amp
Just think about that.
Think about what's causing the buzz.
Clue: It's not the amplification of the output, so being plugged in (or not) is irrelevant to the cause of the problem.
If the strings are hitting the top of the pickup covers - because the pickups are too high and too close to the strings - you'll get buzz, just the same as if they're hitting the top of a fret. With the strings unfretted, those p'ups look too high, assuming that your neck relief, action, bridge & nut height (et al) are all set correctly - which is a dangerous assumption of course. When you fret the strings, the gap between the string and p'up will be reduced. Of course, the gap will reduce progressively as you fret the string at high frets, so the likelihood of buzz increases. Even when you're not plugged in.
Indeed. So take it to a professional and have them do a proper job. Or try a set-up course so you learn the skills yourself and spend a little money on some appropriate tools so that you can do the job properly.
Endless tweaking of truss rods won't help if you've got a high fret or two. Endless fiddling with bridge/nut height won't help if you've got a p'up cavity that's incorrectly routed ...
It could well be the frets that are the problem, but my feeling is that's not it. But I could be wrong. I ran a straight edge along the frets and nothing stood out.
Can you physically push the pickup down into the cavity if you press on it? If so it's just the screws that are the problem if the heads are chewed up (common on cheaper basses) so they need to be replaced. If not, there may be too much padding/rubber under the pickup.
Surely if they were the cause of the buzz, it would be ubiquitous. Why would only a few notes on the E string buzz if it was the pickup?
The screws are the problem; there are two per pickup and one one each is just too stiff to shift. I have the right tool but all i'm doing by trying toscrew it at this point is chewing up the hole. I tried spraying some wd 40 but it didn't do anything. Maybe a professional with better tools would have more luck, but for now that's all I can do.
If it's the padding then I'm leaving that where it is, I'm not going to remove the strings and try and take the pickups out myself I'm afraid.
Sorry, but I'm struggling to see that it's the pickups. I don't know for certain but it's not ringing true for me.
It could *also* be combined with slightly uneven fretting, and/or the action just being too low, but that doesn't rule out the pickups.
If you want to fix this you're going to have to figure it out yourself.
