Vox AC30 - what have I been missing!
  • DodgeDodge Frets: 1445
  • IvisonGuitarsIvisonGuitars Frets: 6841
    edited January 2017 tFB Trader
    @Dodge Very nice indeed! Which sounds best??
    http://www.ivisonguitars.com
    (formerly miserneil)
  • MoltisantiMoltisanti Frets: 1133
    maybe a daft question - but why are they so heavy if they are 30 watts (suggesting a small transformer) and el84 powered which i associate with lunchbox heads ?
    They both have their charm. The later one is a little tighter and feels a bit more dynamic, the earlier one is smoother and more rounded. Still close though and make a fine stereo pair.
    The earlier one obviously has more mileage on the clock which could explain it. Different transformers too (still original though).
  • ICBMICBM Frets: 72497
    Other way round... very big transformers for a 30W amp - which is one of the reasons they sound so full and powerful for the power rating - plus an unusually large choke, two heavy speakers and a pretty heavy cabinet.
  • rsvmarkrsvmark Frets: 1383
    @dodge - I assume those are attenuators on the top?
    An official Foo liked guitarist since 2024
    Yeah, they're Jettenuators. They work pretty well with AC30's to a point. Anything less than halfway is unsurprisingly pretty naff.
  • VoxmanVoxman Frets: 4726
    The AC30! D
    edited January 2017
    But isn't the power rating a complete misnomer because its only relevant up to the point of break-up - whereas in reality it's more like double that?
    A good AC30 is worth the weight....easily.
    Voxman said:
    The AC30! D
  • I just watched this doc recently, "Dick Denny and the Vox AC30" on youtube, quite interesting,
    I've never played through one but now I want to.
    No, an AC30 puts out 30W clean (roughly - I think 33W 'RMS' in fact) like any other properly-rated 30W amp, and more than that overdriven also like any other proper 30W amp. In fact due to the heavy compression when a Class AB cathode-biased amp is overdriven, the AC30 puts out *less* maximum distorted power than something fixed-bias like a JTM45.
    The difference in transformer size has a bearing on the bandwidth when the amp is pushed hard though - bigger transformers don't narrow the tone into the midrange as much, so the result is a bigger, fuller sound when overdriven which both sounds louder and can actually produce more power. (A JTM45 also has big transformers.)
    @DulcetJones - I hadn't either. It's highly recommended particularly if you can crank it up
