suggest a guitar amp for my singer...
  • ddloopingddlooping Frets: 325
    Fender Mustang III v1, like the one I'm selling? :)
  • mrn1989mrn1989 Frets: 240
    Fender Frontman 212R - Loud, Sounds Great, Reliable and Cheap!!!
    Fretboard Feedback https://www.thefretboard.co.uk/discussion/58705/  ALSO Over 500+ 100% feedback eBay transactions
  • A Laney VC30 1x12 combo can occasionally be picked up for £200 (or not much more if your budget can stretch a little). All valve, great sounding, plenty loud and takes pedals well. Failing that, i've seen the smaller VC15 go for as little as £130. Both decent amps for the money
  • John_PJohn_P Frets: 2750
    Thanks for the ideas - hearing my twin last night made him realise how thin his amp sounded so I'm sure he'll pay a bit more.  I'm just a bit out of the loop with combo's at that sort of price.
    If he upped the budget to £300, then surely that would open up more options...
    This is more what I had in mind - a no frills giggable combo that can take a bit of use.
  • monquixotemonquixote Frets: 17640
    As others have said a Frontman or a Transtube Bandit would do you well, but my recommendation would be an LC50 you should be able to get one for not much above your budget and they are a proper pro valve amp.
  • bertiebertie Frets: 13569
    ICBM said:
     and they blow speakers (easy fix, not so low cost) - apart from that they're great. Even the overdrive channel is pretty good.
    yep,  he had a speaker go on first use
  • IanSavageIanSavage Frets: 1319
    That's a good call actually, Laney stuff is tremendously under-valued used. I'd also second the shouts for Fenders silverface-looking SS combos, I've had a Deluxe 90 and worked with a guy whose main amp was the 65 Watt version (Princeton) and they both had tremedous clean sounds (drive was a little thin) and took pedals well.
  • Laney VC or Vox AC15.
  • ICBMICBM Frets: 72442
    The Fender Princeton Chorus (2x65W 2x10") is a great amp - I got one of the best sounds I've ever had with a Mesa V-Twin through one. The others in the same series are good but not quite as great, for some reason.
  • JayGeeJayGee Frets: 1260
    I've used one of those too, although in my case using the line-out of my Super Champ. Genuinely nice amp.
  • 57Deluxe57Deluxe Frets: 7339
    Just make sure his tone ain't better than yours... so I'd get him an Ibanez Valbee... they sound shit enough...
    <Vintage BOSS Upgrades>
