If he upped the budget to £300, then surely that would open up more options...
This is more what I had in mind - a no frills giggable combo that can take a bit of use.
That's a good call actually, Laney stuff is tremendously under-valued used. I'd also second the shouts for Fenders silverface-looking SS combos, I've had a Deluxe 90 and worked with a guy whose main amp was the 65 Watt version (Princeton) and they both had tremedous clean sounds (drive was a little thin) and took pedals well.
