Fender 65 Deluxe RI
  • ICBMICBM Frets: 72619
    edited March 2017
    james said:
    I'll give that a try. What do I jumper to what? Normal 2 to Reverb 1?
    Yes.
    57Deluxe said:
    you need a phase correcting cable to jumper Deluxe and Super Reverbs...
    No, you just need to set the volumes not too similar to each other - you want to do that anyway to avoid reintroducing too much brightness via the vibrato channel. The idea is really just to use the vibrato channel as a side chain.
    A phase-correcting cable - assuming you mean the sort you would use with a speaker cab - won't work with signal inputs anyway. You would need an audio transformer to reverse the phase.
  • @ICBM What the fuck. You've just blown my mind.
    I've just tried this on my 68 CDR and it's fucking great. I've dialled the treb and bass down to about 2 on the Custom Channel, and then dialled in the treb and bass on the vintage channel (7 and 4 respecitively). I now essentially have channel 1 as a dialable mid-range channel.
    How does the EQ work on these amps? Are they Baxandall type tone stacks?
  • If you're thinking of buying new, I'd consider £2-300 more on a Rift Amps Fender Clone! Really, a relatively modest increase for much higher quality, hand-wired, easily maintainable etc.....
    edited March 2017
    No, the standard 'guitar amp' type. Not many guitar amps actually use Baxandalls (or the simpler 'James') type - although old Oranges are one example.
    I've just tried this.
    HOW BLOODY BRILLIANT IS THAT!?! Really brings drive pedals alive.
