Bass playing is hard on my back, anyone have a solution?
  • bassborabassbora Frets: 132
    @Rocker ; I know people are suggesting lighter basses and that's what I would do but to answer your question I remember seeing Tom Araya talking about just the thing you first mentioned in your OP.  If you watch the rig rundown for slayer https://www.youtube.com/watch?v=GlvaYmvyDmk and go in around 14:30 he talks about having a belt around him and hook the bass on that.  Check it out.
  • JezWyndJezWynd Frets: 6060
    Mentioned the Club Bass earlier. There's been one on sale here for a while. It's the modern style model with a solid centre block which gives (apparently) more modern tones.
    http://www.thefretboard.co.uk/discussion/86266/
  • RockerRocker Frets: 4981
    The mock up revealed a lot.  70 cm is way too high for me, something around 60 cm suits me better.  And with both feet on the floor and a shortened strap, the bass 'moved' closer to my ribcage.  A more comfortable playing position.  A half hour playing showed no ill effects.  I then 'modified' my drum stool/seat to the new height.  Now I have to wait until the next music evening with my friends so that I can try out the modified seat.  As someone suggested, this means playing bass while sitting.  Fine by me, just more kit to move.  A benefit, alluded to by @Bridgehouse, the slightly different position of the bass makes it easier to position my thumb behind the neck.  A few hours practice and that new position will become permanent.
    Thanks to you all, I will update after the next music evening.
    Nil Satis Nisi Optimum
  • GassageGassage Frets: 30913
    edited April 2017
    @Rocker - I had back pain first time I played for an extended period of time stood up - the thumb position and strap height both alleviated it considerably..
    @Gassage, I have a medical problem that restricts my standing.
  • fretmeisterfretmeister Frets: 24273
    Strap length is a little thought about issue.
    It might not look as cool to have the bass higher up, but it can make a lot of difference.
    Helps relieve neck dive too. Not sure why, but it solved the problem with an SG bass.
  • Dave_VaderDave_Vader Frets: 360
    Yeah, it totally knackers my right shoulder if I have my bass up high, need the strings at the end of my right arm or I'm in agony.
    Guitar with an octave pedal do?
  • funkyfrazfunkyfraz Frets: 93
    A nice wee medium scale number is surely ideal. They work alot better as a bass than you might think, and it's not cheating. Not sure why any other option would be 3ven considered.
  • FunkfingersFunkfingers Frets: 14426
    +1 for all of the comments about not slinging the bass guitar excessively low on a strap. It is a musical instrument not a penis extension.
    Former Guitarist magazine editor, David Mead, always recommended finding a comfortable seated position with your chosen instrument. Adjust the strap so that the instrument remains against the same part of your abdomen, regardless of whether you are seated or standing.
