One brand only...?
  • Boss, Ibanez and ISP for me, cos that's all I have on my board (tuner, OD and noisegate) Keep it simple!
    I do own other Boss pedals though such as the SD-1 and DD-6 delay but I don't use them much.
    ThorpyFX said:
    juansolo said:
    Cabicular said:
    Just waiting for @ThorpyFX to do a delay and a flanger and I'm all set!
    I'd be surprised if you see a Thorpy Flanger. Flangers are very complex pedals.
    Why the surprise? I am working on an analog flanger, a chorus,  a phaser, etc.... they are indeed complex and we need to get the balance right between a commercially available product that isn't too functionally complex and therefore too costly. This unfortunately is taking a lot of time to get right, however myself and Dan Coggins are confident it'll be right once finalised.... otherwise i won't bother. oh, that and I have a whole load of Nos Analog BBD chips I want to utilise :)
    I'm in
  • I exclusively use Glab, Boss, Eventide, TC and Donner, Bright Onion...oh and Jim Dunlop.
    Hate those Mix and Match guys.
  • SporkySporky Frets: 28347
    Line6 - I'd have a Helix and a Helix LT.
    ICBM said:
    Since I decided I would never again own a pedal with a metal click switch (the Dunlop doesn't really count because I like it), it became fairly easy to just go to all-Boss… although I wouldn't rule out a 9-series Ibanez of some sort.
    Corrected the bit in italics. ;)
  • Darkglass.
    They don't do an octave pedal which is the only other thing I'd want. Otherwise I agree they've got it nailed for bass sounds.
    Would happily use all Boss for guitar, except I like the ISP Decimators for noise gates
  • ICBMICBM Frets: 72384
    Ha :).
    Not really... my objections to metal click switches are that they're unreliable - this one is a SPST so it shouldn't be anything like as bad as a 3PDT or even a DPDT; that they cause clicks if used in the signal path - this one operates a buffered switching system like a Boss; and that I hate the feel of them when I play with bare feet - the wah treadle stops this. So none of the reasons really apply.
    But I may still be tempted to give a Boss V-Wah another go...
    edited August 2017
    I like the FT-2 with an expression pedal as a wah.
    In answer to the original question, I'm close - Line 6 Helix is the only effect, but I do have a Source Audio Reflex to control it...
  • tone1tone1 Frets: 5170
    Yes, I'm a mentalist and quite often go all one brand of pedal, with EHX being the most recent bent....I'm back on an even keel now but still have 3 Thorpyfx 's  on my board  B)
  • ROOGROOG Frets: 557
    I have a strymon board of three at the moment, not really a board!
    ICBM said:
    Ha :).
    I'll save you the bother .. it's terrible
    its their weird Achilles heel
  • polotskapolotska Frets: 116
    Boss makes a more conventional wah now, the PW-3. Never tried one so I have no idea how they sound, but I like the enclosure much more than a traditional Vox or Cry Baby—it’s the same design as the Boss FV-30 compact volume pedals.
  • Even as  big boss fan I hated the V-Wah.
    Horrible switching and sounded yuck.
    That's what I thought I remembered :). Forget that idea then...
    The PW-3 looks like it may be worth trying. I didn't know about it - slightly confusing name, when the PW-2 is a distortion pedal.
  • shaunmshaunm Frets: 1598
    My board has 7 pedals and 4 of them are Fulltone. They just work well for me.
    I have a Budda Wah and I'm tempted to get rid of that and get a Fulltone wah in too.
  • ICBM said:
    Ha :).
    hippy.
  • Maybe an all MXR board. Carbon Copy, Echoplex, M300 Reverb, a couple of their drives. But I have none of their pedals so what am I blathering about. Thought about an all-Boss mini-board for a while, but not just now.
  • wingo84wingo84 Frets: 42
    5/9 on my board is Xotic
    EP / AC / RC / SL / XW1
  • GassageGassage Frets: 30926
    So, the synopsis- there's a delay with the delays.
    I know they get a lot of derision but I used one for ages and it's fine as long as you just stick with the wah and leave the distortion alone.  (Although if anyone could get a usable sound from it I guess it would be you!)  I put the precaution of a big blob of blu-tack on the distortion knob to stop it accidentally switching on.
    The wah is perfectly wah-y with some varied voicing; the distortion is seriously... unique.*
    * Never one to let a potential spam go just PM if you want to buy my old one.  And I could even supply another blob of blu-tack if required!
    Hmmm…
    PM'd
