You should be able to load AD as a VSTi in your DAW. Then open up the AD VSTi interface in your DAW and drag the AD midi pattern into your DAW. At least that's what I do in Reaper, if I want base a drum track based on an AD pattern which I can then edit.
Below is a link to a video I created (with no sound).
https://app.box.com/s/fo1rxhdb2vhg1etdn004d2jelmjmnsax
There's a Play button at the top, just to the right of the Addictive Drums logo.
https://www.thomann.de/pics/bdb/399369/11454096_800.jpg
EZ Keys looks interesting, any users here?
Just downloading it all now.
https://forum.cockos.com/showthread.php?t=197289
The Modern presets seem to cover a lot of ground;
Basic/ 80's/ Disco Pop/ Distorted/ Dry Rock/ Metal/ Modern Vintage/ Pop/ Power Batter/ Prog Rock/ Ringy Rock/ Roomy Rock/ Small Room/ Studio Blues/ Tape Filter/ Tight/ Original Mix
It's... Meh. I use it more as an fx over midi, for that it works well but it's not as good as EZ drummer for quick, good results
