help needed authenticating and pricing
keithfkeithf Frets: 371
edited February 2018 in Guitar
Guys, I have a chap wanting to give me this in a deal against my jp6, can anyone advise on its worth and authenticity
Its a custom shop vos nickle I'm told.
thanks in advance
https://i.imgur.com/yrvIxnw.jpg
https://i.imgur.com/GlwAPpM.jpg
https://i.imgur.com/W5rtFiP.jpg
https://i.imgur.com/qY1xlj7.jpg
https://i.imgur.com/xF6SDr7.jpg
https://i.imgur.com/bQH5i7u.jpg
  • guitars4youguitars4you Frets: 14254
    do you have pics of the rear of the headstock with serial number
    any Custom Shop Certificate with it - in a CD size leather brown wallet
    Should have tags and the gold warranty info sheet which will also have the model number on it
    looks okay so far based on pics I can see
    Must have been a small run with nickel hardware and aged finish
  • keithfkeithf Frets: 371
    does it have any certificate with it - wallet format or A4 paper certificate - if it is a 2014 model it should have a wallet certificate with it
    I'ma bit confused at this stage - the serial number is probably 2014 (thanks to the 4) - the next 0 would then indicate Nashville and the 0812 indicate how many made to date in that year - But I can't recall a C/Shop LP Custom with this level of wear/age on it - Easy to forget as Gibson duck n dive so much on small limited runs and I'm a bit cautious as to a previous owner has undertaken additional wear ?
    They did an LP Custom around 2004 period with nickel - but the switch backplate cover indicates a later era
    Any LP fans on FB seen this exact model before
    so, it turns out the wear is self induced, He does have the certificate as well.
  • I would assume it's a 68 reissue with plenty of actual non-factory wear - they've done plenty of those with nickel.
    Like this one: https://reverb.com/item/1503509-gibson-68-reissue-les-paul-custom-2006-black-w-nickel-hardware-owned-by-jon-schaffer-of-iced-earth
    Looks nice but might weigh a lot.
    ^^^^^^^^^^^^^  I can't make out that serial number on the reverb link - in many ways a C/Shop is the same/similar to 68 replica but a different serial number system - The above reverb link appears to be a 68 replica whereas @keithf enquiry is about a non specific dated Custom Shop model - not really better/worse as a guitar - I suspect it has been aged further by a previous owner - suspected not certain -
    Does it have an ebony board - rosewood (I know Gibson ran a few with rosewood) or richlite
    based on what I know and seen so far and based on what an 80's or 90's LP Custom would sell for then min £2000 and maybe £2500 if patient - mint then more but not with that wear
    hope that helps
  • BrizeBrize Frets: 5629
    It's not a '68 reissue because the *last* digit of the serial number would be an 8. It would also have an ABR-1 bridge rather than a Nashville, and kidney bean Grovers or waffleback keystones rather than regular keystones.
    This is a regular 2014 Les Paul Custom with nickel hardware, possibly with changed knobs and with a rosewood or richlite board. These retail for around £3k so the second-hand value would be c.£2k, but much less in this case given the wear.
    I'd say the lame attempt at ageing would limit its value to £1k. This would be a hard guitar to shift for any more than that.
  • FunkfingersFunkfingers Frets: 14428
    There was. A guitarist in my town had one but didn't gel with it. He sold it (and a terrible amplifier) to a friend of mine.
    The friend applied a 6x7" black band name sticker on the body, between the tailpiece and the strap button. More significantly, he would insist on wearing a thumb ring whilst playing. This left a succession of criss-cross indentations along the back of the neck, just below the binding - almost where the finish has been lost on the OP guitar.
    When I first saw the OP photographs, I wondered whether it was the same guitar. My friend's example had Jim Dunlop strap locks fitted. I don't recall a "special" selector switch cavity cover plate but it did have a decal on the back of the headstock. I cannot recall whether it read Custom Shop or Historic.
    My friend kept the Certificate Of Authenticity. It is the orange Custom, Art & Historic type with the white boxes for the model ID and serial number.
