Low gain drives
  • menamestommenamestom Frets: 4720
    Juansolo ‘The Enchanter’, use mine with a Princeton.  Works great adding a bit of hair to the sound without changing it much. Versatile e.q.    Timmy based but the controls are the right way round and is a bit smoother.
  • munckeemunckee Frets: 12399
    I also use a compressor (marshall) to provide boost/sustain to clean playing.
  • crunchmancrunchman Frets: 11460
    Kebabkid said:
    Xotic RC Boost, Way Huge Pork Loin, Liquid Sunshine or the Catalinbread Formula 5S.
    I've had them all at some point and I've stuck with the Pork Loin. Surprisingly, the OCD on very low gain (8/9 o'clock on gain) is good.
    Have you tried it on 18V?  Even better.
  • agibboagibbo Frets: 102
    I've been through a fair few low gainers, and the Timmy does it for me through my Princeton!
  • stickyfiddlestickyfiddle Frets: 27114
    Anarchy Audio Gold Class. Absolutely exceptional pedal. Not sure they have any dealers in Europe, mind..
  • Chris_JChris_J Frets: 140
    I use a greer lightspeed. Great pedal!
  • David5150David5150 Frets: 118
    Mad Professor (well the cheap Joyo clone) did the job for me when I used pedals for this kind of sound
    Nice pedal
  • KebabkidKebabkid Frets: 3311
    I will do one day :)
  • shaunmshaunm Frets: 1612
    I may do this as the OCD is on my board but I’m not using it as I’m favouring fuzz’s these days.
  • Adam_MDAdam_MD Frets: 3420
    Running an ocd at low gain settings on 18v is pretty special imo.  I keep meaning to put two of them in one box so I can switch between them as I use an ocd for my main distortion sounds too.
  • leerockerleerocker Frets: 607
    Completely agree , the ocd at 18v low gain is great and knocked a few expensive pedals off the board . i find v1.7 is better sounding than the new v2.0 they brought out for lower gain stuff
  • The Timmy is my favourite. I've also tried a Rockett Archer, Emerson Em Drive, Barber Ltd, Tubescreamer, Zen Drive
    SD-1 or the Waza SD-1.  Both sound amazing - the Waza is my favourite OD ever.
  • KeefyKeefy Frets: 2288
    Origin Effects SlideRig, or Boo Instruments TS-OD, plus riding the guitar's volume control.
  • Matt_McGMatt_McG Frets: 323
    I've made (good quality) clones of the Zendrive, Honey Bee, and the Durham Sexdrive.
    The Zendrive is pretty versatile, but I don't find it very inspiring. The Honey Bee, on the other hand, is pretty great, and has amazing touch sensitivity. You can go from jazzy cleans to crunch and smooth lead just via picking.
    The pick of the bunch, though, is maybe the Sexdrive. I don't like it with the gain wound up much past half way (although that's a nice crunchy sound), but with the gain down a bit, you get a fantastic clean boost, with a little bit of breakup, and a really amazing EQ/compression thing happening, that brings out loads of sparkle and harmonic complexity, without overtly colouring the overall tone. It's just a "make everything sound more expensive" button.
  • NorthernStompsNorthernStomps Frets: 398
    For a Klone, check out the Fredric Effects Golden Eagle.
    if its a standalone drive you're after have a look at a magnetic effects Sandare, which can work as a boost or overdive. Theres loads to choose from!
    If you want to get a great sound without breaking the bank, you honestly cant go wrong with the Raygun Fx Soda Drive. Three different gain types and sounds ace!
    Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
    Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
    Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
  • BluebeardBluebeard Frets: 228
    edited April 2018
    I use a Tone City pedal called Sweet Cream. Its a £40 mini clone of the one of those Honey pedals. Its got a really nice bluesy low drive that I keep coming back to and it really reacts to picking/volume dynamics. Probably my most used pedal despite having others that are more expensive.
    I used to have (and sold) a Sweet Cream. They are great. Amazing value for money.
    I only sold it because I built the Honey Bee (and didn't need two near-identical pedals).
    Definitely.  I've had a Klon KTR and a Lazy J Cruiser that I've sold on.  I've got a Thorpy Peacekeeper that I'm thinking of selling as well.  The OCD has been pretty much ever present for many years.
    Of note. I tried stacking 2 OCDs (one on low gain and one on medium) and it didn't work. A TS type pedal or EP Boost works better with the OCD.
