Pickup winding machines....
sixstringsuppliessixstringsupplies Frets: 429
School me.
I’ve ummmmmd are arrrrrrd for months over whether or not to get into pickups.
but running a guitar electronics business...it’s inevitable one day and something I would love to try out.
what winding machines would you recommend?
any experience/knowledge would be great.
For Modders, Makers, Players
https://sixstringsupplies.co.uk/
Our YouTube Channel for handy "How-To" Wiring Tutorials
  • RolandRoland Frets: 8713
    Which part of the market are you targeting? Rather than committing the time and capital it might be possible to work with one of the small UK winders.
  • ClashmanClashman Frets: 176
    Couldn't you use the copper wire from old radio's or is it too thick?
  • WezVWezV Frets: 16689
    I have an original copy of the lollar book on making a winder.  I wouldn’t recommend it, other than to show 1 specific way of building a DIY winder with very specific parts.
    I would probably buy or make a version of  the schatten winder as a first port of call.  It’s basic but will get you into hand winding.  Then you just need to wind and test a few dozen until you start to get some consistency
    I should say, my first was done with a drill press set as slow as possible and a very crude wire guide.  I managed to make a trio of 6k strat Pickups that sounded okay.  Made a couple of humbuckers too.  Then ticked it off the list and carried on paying others to do it
  • sixstringsuppliessixstringsupplies Frets: 429
    given the competition and we are truly spoilt for choice in the UK for boutique/high end pickups, it would only be a mid-range to complement other products on the website.
    With that in mind....probably a non-starter.
    drill press: love it. I watched a video last night on converting a sewing machine into a coil winding machine which has given me the bug.
    I agree though - for the moment probably best to leave the pros to it.
  • m_cm_c Frets: 1241
    Have a search for coil winder.
    A basic one wouldn't be that hard to make. Personally for something basic, I'd make a holding jig that fits directly onto a stepper motor, use a cheap stepper driver controlled via an Arduino for speed control (Arduino means you can use a potentiometer for speed control without much effort), add an LCD for rotation counting, and through in a bit coding.
    Other option would be a small DC motor (would likely have to be a geared motor to get sensible RPM), a basic PWM controller, and potentiometer. Simpler on the electric side, but you could add a basic pulse counter to get the number of turns.
    I have a cnc one but it's a dear do.
    is that this beast?
    is that this beast?
    Yes. A tiny beast to be fair.  :)
