Andrew Scheps - Omni Channel Strip Plug-in (Waves)
13»
  • guitarfishbayguitarfishbay Frets: 7960
    No, Q10 is just a 10 band EQ, it doesn't do any dynamic bands.  F6 does dynamic bands.
    Q10 is probably not worth getting if you already have a nice digital EQ plugin (e.g. Fabfilter Pro Q2).  Though I actually do use it myself, but mostly because you can always see the controls for all bands... I sometimes like to automate my EQ to have specific control rather than trying to get a dynamic band to react the way I want, and having all the controls always available makes that easier to write automation in real time.
  • duotoneduotone Frets: 983
    ^ Thanks @guitarfishbay ;
    I'm new to all this plug-in lark & don't want to end up with 2 things that do the same thing.  Would rather buy one at a time and get used to using them, than buying a whole bundle & being overwhelmed.
    I downloaded the F6, for the 7 day trial...will let you know how I get on.
    I like F6.  If you can get it on a $29 deal it's worth it IMO.  Also be aware that there's usually an active discount code for Waves, I think the current one is YNY23.  Buying from a website such as Audio Deluxe is usually cheaper than going direct.
    I'll check https://www.audiodeluxe.com , yeah its $29 on there as well, so the same as the Waves website. Will let you know about that discount code if I purchase it.  Actually that code is the same one I used when I bought the Scheps Omni-Channel!
    I found the discount code here on a review: https://www.audiopluginguy.com/review-scheps-omni-channel-from-waves/
