Nice one, I may just get it then!
Advantages - each mix channel has access to the effect by turning up the appropriate knob, you only need one instance of the plug-in thus saving Processing Power, and you will get a more realistic room reverb, for example, if all sounds are being treated by the same reverb, similar to what happens in a real room. Also you can have a stereo effect being accessed by mono signals which is going to sound stereo-er than having the plug in as an insert on a mono channel. It is possible to put both reverb and delay on the same aux channel, but you then lose individual control for no benefit.
My aux return channels always stay at 0dB, I vary the amount of fx on the source with the aux send knob.
Of course there are exceptions to every rule, but generally time based effects like reverb, delay and chorus go on an aux send/return loop whereas processors like compressors and eq's go on channel inserts.
