Marshall super bass
  • SunDevilSunDevil Frets: 511
    If you want the non-MV plexi experience without needing a big room to play it I’m, what about pulling 2 (inside or outside pair) of the EL34s to bring down the headroom (remembering to drop the impedance, so run the amp at 8 ohms into a 16 ohm cab)!
    combine that hat with a smaller dose of attenuation maybe?
  • ICBMICBM Frets: 72442
    That works, but only gives a 3dB reduction which is not a lot really.
  • I've got a 100W SuperLead. It's ANIMAL. Haven't gigged it in years (used to get told to turn it down even when using a 45W Plexi). Great for recording though with an SE100.
