Q418C Poopot jnr...
  • poopotpoopot Frets: 9099
    Roland said:
    It’s nice to see people make stuff rather than take the easy option and buy it. Keep up the good work, and the photos.
    Tbh... absolutely no way I could justify the cost of the original that I am replicating here!... ;)
  • DanielsguitarsDanielsguitars Frets: 3297
    edited November 2018 tFB Trader
    You can't buy anything like this unless it's made, there's no easy way for any of this stuff, the easy part is it's a flat top build so fairly easy and quick
    www.danielsguitars.co.uk
    (formerly customkits)
    Bit more progress today...
    Planed the maple filler strip flat...
    Then added the taper to the rosewood handle cover...
    Cut the slots for the metal line markers in the rosewood handle cover...
    The stuck the rosewood handle cover to the handle... (just with double sided tape)
    Then used the pin router to transfer the taper to the handle
    The handle test fitted to the handle holder...
  • RolandRoland Frets: 8731
    How did you measure and mark the positions for the fret slots?
    The bed of the fret slotting jig has a template underneath which sits on a pin. Locate the first position, cut a slot and then move the whole bed along to the next position and cut again
    Neck angle sorted.
    Starting to look like like a tennis racquet...
    Off to thickness the handle cover!
  • merlinmerlin Frets: 6705
    Dibs!
    Loving this thread!
  • robertyroberty Frets: 10893
    Great work!
    Who works with their coat on   ;)
  • Nice work :)
    A jumper and gilet I’ll have you know!... :)
    bloody cold down on the farm!
    Bit more from the frozen tundra that is the workshop...
    got the ears glued on the headstock...
    Got the tunnels drilled for the line position circles on the handle cover...
    Strapped the handle cover to the handle cover rounding jig... then gave it a good 12” rounding...
    The rounding jig did a bang up job of rounding the handle cover!!!!!
    Then finally the position circles were melted into the tunnels on the handle cover...
    Hopefully the next update will see the handle cover bluetacked to the handle and maybe the handle bolted onto the handle holder using hot hyde glue!...
  • DougDoug Frets: 172
    Love it!, keep the build process pic's updated, Thanks :)
    you sure those dots are all in line
    Love that radius jig, makes light work of doing multiples
  • paulnb57paulnb57 Frets: 3055
    Enjoying this build, nice work!
    Mine deffo are... and first time as well ;)
    More progress....
    headstock shaped...
    Neck thickness sorted... will be “chunky”
    Side dots done...
    Headstock transition roughed out...
    Starting to look like a banjo!...
  • Nice work.  Would love to do the same but I don't think my faded 'O' Level woodwork skills are upto it!
    He has had a bit of help not f##king it up, all the power tools do is ruin things far quicker than by hand
    It's just practice and there are things like ready made fretboards that'll help
    Oi! I bloody made that fretboard as well you know :)
