https://www.wembleymusiccentre.com/quilter-microblock-45-amp.html?gclid=EAIaIQobChMIh6Xp8snh3wIVirztCh2PFw1wEAQYASABEgIW5fD_BwE
Or you could use the FX return of one of the bigger (yet still small) Quilter heads... 101 or OD200 for example.
the SD powerstage seems an awful lot of Money for what it is, the quilter looks only a marginal improvement on the baby bomb, may look st the quilter heads. Also tried a DV Mark micro, was ok as a power amp, but an awful amp on its own so seemed a bit of a waste
https://www.thomann.de/gb/mooer_tube_engine.htm?glp=1&gclid=Cj0KCQiA1NbhBRCBARIsAKOTmUtNsKydH4qJmMmfb2WtGuEf6qWpJxHzHJtPYeRTFTLmxcASSgTkoOQaAs4rEALw_wcB
The Camplifier GAB is a bit more expensive, but smaller.
Irony of ironies, you can get a Jet City JCA22H and just not use the preamp for much less, and the JCA20HV for even less than that.
Alternatively, there's a Rocktron Velocity 300 in a 2U rack that'll be light and loud enough in the Classifieds for £100. Bit of a bargain, that.
http://www.hotoneaudio.com/products/Nano_Legacy_Floor/Nano_Legacy_Floor/2018/0606/278.html
Their new stuff looks a step up from dinky pedals.
Dont really want to go rack mounted
@ben is the powerstage much better than the ehx?
like the TeacAmp I’m selling....
only 2.1 lb.
Not much bigger than a book.
What bugs me about all the pedal-sized power amps is that they're rated for max power at 4 ohms, where almost nobody in the guitar world uses a 4 ohm cab; 8 ohm is the minimum, really, and they all deliver half the power in that situation.
Sounds great, but bit overkill for my needs
Sorry I'm being a pain Wish Matrix or Palmer would do a mono amp half the size of the 19" rack
https://cpc.farnell.com/monacor/pa-702/70w-pa-amplifier/dp/DP26108?st=amplifier mono which is really not suitable all the I/O isnt really guitarist friendly
...and this one, which probably doesn't meet the OP's cost criterion, but looks interesting nonetheless:
https://www.pmtonline.co.uk/orange-pedal-baby-100-amp-head#product-details
I'd have thought @ecc83 would be all over it, given that it appears to be a proper Class A/B amp designed for guitars. Having the tone stack disengage with both controls at noon is also a nice touch.
I suppose it depends on when they're actually available to buy. I get quite tired of vapourware these days.
