I don't care so much about the sound - even though I thought the Powerblock was probably the worst-sounding amp I've ever tried, worse than the Micro Terror - but guaranteed reliability is critical for a backup, unless you want to take *another* backup for the backup...
Hence I would rule out both the Powerblock and the EH Magnum even if they sounded fantastic.
I could try, but it'd just be a poorly shot and recorded iPhone clip.
Just bout powerful enough, combine with emulated line out from amt, tech 21, joyo, blackstar, ehxtortion...
http://www.thomann.de/gb/the_tamp_pm40c_endstufenmodul.htm
When you can just chuck a great sounding backup valve head in the passenger footwell for that price it seems silly to attempt to shoehorn underpowered or inappropriate gear into your rig.
Now that deserves a wisdom. I'm off the check out some demos.
Very valid point about the jet city, if rock is your thing... Wisdom there.
Soldano tones for that money can be nothing else.
I am hell set on getting a jca22h and Harley Benton 2x12.
More amazingly, there are overdrive and distortion pedals out there that cost significantly more that probably emulate the soldano lead sound...
One of those could sit on the pedalboard ready for use - looks a very handy little box to me
