The new guitar ive just picked uk has come with elixir nanowebs and they feel a little strange, there’s more tension for a smaller gauge than I’d usually use and it’s almost like I can hear the coating against the frets if that makes sense?
Ill be swapping back to slinky’s.
I’m not going for that dark a tone - I don’t want a jazzy muddy tone. I don’t like the brash brand-new sound though.
I do have Reynauds, and don’t sweat much.
Yes, I use 11s, play mostly chord/arpeggio rhythm. I do bend strings, but don’t use a lot of vibrato. I actually hit the strings quite hard, but I don’t use a pick - not sure if that makes much difference.
Brian May uses 8s, plays lead with a sixpence, and still never changes strings - I think he said 2 years or more wasn’t unusual as well.
Ive 9s on my Les Paul and I'm thinking of changing to 10s, would this mess with the intonation?
Slightly. TBH you'd probably get away with it.
Suppose you could buy a single 10 string and string it alongside the 9 and do the same to compare that.
When I compared the 9 and 11 the difference was enough for me to assume that even though the difference from 9 to 10 will be smaller, it will still be quite clear.
Also, as you go down the strings, there will be more than 1 thou difference between the strings from each set.
I'm enjoying the sound of non-coated strings on acoustic at the mo, but I get about 3 months out of a set of 80/20 bronze, compared with at least 6 months from Elixirs, so I'm not sure if i'll stick with them.
Medium - 10 13 17 26 36 46
https://www.amazon.co.uk/DR-Strings-Blues-Nickel-Round/dp/B0009FUUO2/ref=sr_1_1?ie=UTF8&qid=1513036818&sr=8-1&keywords=dr+pure+blues
That was my thought when I read that comment. I'd rather change strings slightly more often than need a refret years sooner.
Strings are dependent on body chemistry. Once I was playing with a young guy once who had an Epiphone Les Paul, so I let him use my Gibson for the weekend. After maybe 6 hours of playing, the strings on my Les Paul were totally corroded and black. I could have left them on there for two years and they wouldn't have got like that.
If you have body chemistry like that then coated strings might be an unfortunate necessity. Personally I really dislike them though.
