Is that what you are looking for? To reduce the full up gain sound of your amp?
If so - a good EQ is great, or the HBE Detox if you can find one.
So - all of them.
Boss Blues Driver Waza is very nice for a nice even drive without a mid-hump.
They have no grit / gain at all. Just a controlled gain reduction with EQ - to lower the signal going to an overdriven amp without adding any sound at all - transparent. It's like adding a clean channel to a single channel amp, rather than the traditional way of running an amp clean and then using a dirt pedal.
For most amps the dirt is in the mids so these pedals allow a larger gain reduction in the mids while keeping the bass and treble where you like them.
I've not tried one personally, but they get a lot of love if it's within your budget.
You also can't go wrong with a Timmy, or a Blues Driver.
Most versatile light overdrive on the market IMO and budget friendly too.
https://shop.pedalparts.co.uk/Germanium_Tart/p847124_19985861.aspx
Xotic RC
TC Spark
Klon(e)
Zoom Power Drive (they turn up on eBay - GREAT lowish gain OD pedal imho)
ThorpyFX Peacekeeper
Dunno about the mini version, but the full size sure does (I used to have one)
