Sorted: light drive recommendations?
notonlybutalsonotonlybutalso Frets: 110
edited October 2021 in FX
morning all, after a few years out of the loop i am finally going to build back my pedalboard and i am looking for a light drive to use with my amp channels. I am after something fairly flat and high headroom, only for light grit. I was thinking maybe something bluesbreaker-ish or maybe a nobles, does anyone have any suggestions?
  • fretmeisterfretmeister Frets: 24676
    Some Underdrives are just EQ pedals with no grit at all - they just lower the signal strength in a more controllable way than the vol control on your guitar.
    Is that what you are looking for? To reduce the full up gain sound of your amp?
    If so - a good EQ is great, or the HBE Detox if you can find one.
  • Sorry i wasn't quite clear. I am after an actual gain pedal but i just used the term underdrive as shorthand to mean one that will go under unity gain on its volume knob, it does need to have some gain staging in it.
    I cannot think of a single drive pedal with a volume control that doesn't go low enough to turn off the signal completely.
    So - all of them.
    Boss Blues Driver Waza is very nice for a nice even drive without a mid-hump.
    These are actual UnderDrive pedals:
    They have no grit / gain at all. Just a controlled gain reduction with EQ - to lower the signal going to an overdriven amp without adding any sound at all - transparent. It's like adding a clean channel to a single channel amp, rather than the traditional way of running an amp clean and then using a dirt pedal.
    For most amps the dirt is in the mids so these pedals allow a larger gain reduction in the mids while keeping the bass and treble where you like them.
  • Winny_PoohWinny_Pooh Frets: 7815
    Tc Spark
  • fair point, i have edited the thread to clear that up now cheers
    I suspect you are about to get a lot of recommendations for the ThorpyFX Peacekeeper.
    I've not tried one personally, but they get a lot of love if it's within your budget.
  • monquixotemonquixote Frets: 17692
    Fredrik Blue Monarch is an improved Blues Breaker at a good price.
    You also can't go wrong with a Timmy, or a Blues Driver.
  • SupportactSupportact Frets: 1008
    edited October 2021
    Thorpyfx Peacekeeper does this for me. Because of the way the eq is you can set it to sound like the amp, then add in a bit of gain.
  • Tc Spark
    Second vote for TC Spark.
    Most versatile light overdrive on the market IMO and budget friendly too.
  • Mr_ClawMr_Claw Frets: 95
    edited October 2021
    Drive specifically? Tortenmann/Telnordia TA100. It's great. Can do light drive (and very transparent at low drive settings), can run at 18v and has bags of headroom. I think a few people do clones (originals are hard to get). Fuzzdog have one and will build it for you too if, like me, you can't solder for sh*t.
    https://shop.pedalparts.co.uk/Germanium_Tart/p847124_19985861.aspx
    C
    Another thing I've recommended elsewhere is not actually a drive, but is great at doing exactly this: The CTC Memphis. It's a Magnatone style vibrato, but it runs at 18v internally and the boost/preamp circuit on it is *really* good-sounding. I do use the vibrato on it, but most often I use it as a boost. Really, it's an amazing boost (can also go below unity gain if you need)!
  • +1 for the ThorpyFX Peacekeeper. I've tried a few alternatives, but it's the one that has seen off the competition.
  • thanks for the recommendations guys, looks like i have a good few to look in to
  • stickyfiddlestickyfiddle Frets: 27290
    Probably worth adding the Greer Lightspeed and former forum-darling the Subdecay Liquid Sunshine to the list - both excellent "just add hair" pedals.
    Xotic RC is nice for low gain and good EQ.
  • TimmyOTimmyO Frets: 7580
    depending on how flat you really want/need:
    Xotic RC
    TC Spark
    Klon(e)
    Zoom Power Drive (they turn up on eBay - GREAT lowish gain OD pedal imho)
    Red ones are better.
  • lot of love for the spark already, i didnt even know it had gain in it, that might be the shout for the price
    Dunno about the mini version, but the full size sure does (I used to have one)
  • TC Spark Booster, the full version, not the mini.
