Stratocaster vibrato systems - use all 5 springs please. Leo did that for a reason...
CaseOfAceCaseOfAce Frets: 1336
Not my words but those of Jeff 'Skunk' Baxter in this month's Guitarist magazine when asked about his favourite vibrato systems...
"I'm a big fan of the stratocaster because it's got a lot of play. There are probably going to be people that won't like me for saying this, but use all 5 springs, please. Leo did that for a reason. If you haven't done it, do it. And if you have done it, you're already there. I think it's an excellent system."
Rather frustratingly he didn't elaborate further (or wasn't asked).
So... what's the thinking here? I've only ever used strat trems with 3 springs.
Using 5 would mean less movement possible on the bar, higher tension - but better tone or stability tuning wise?
«13
  • elstoofelstoof Frets: 2464
    When I tried 5 springs and it was so tight I bent the bar
  • simonhpiemansimonhpieman Frets: 683
    Is there something you can do to keep the trem floating and still not have the strings go out of tune on bends? Would 5 springs help that?
  • bertiebertie Frets: 13569
    perhaps use 5 and release the claw a little
  • Danny1969Danny1969 Frets: 10406
    It's generally the nut that causes that issue - assuming the tuners are good and the strings are stretched in. You can get stuff to lube the nut so the strings don't stick in it. If it's a badly cut nut though then you will still have problems.
    I think the Fender 6 screw trem is the best if it's set up right but I'm a 3 spring man
  • JonathangusJonathangus Frets: 4521
    From what I can see, he uses 11-50 gauge strings.  The higher the string tension, the higher tension you need in the springs to balance it.  So five springs with heavy strings makes sense.
    Trading feedback | How to embed images using Imgur
    As for "when am I ready?"  You'll never be ready.  It works in reverse, you become ready by doing it.  - pmbomb
  • FunkfingersFunkfingers Frets: 14427
    Fender electric guitars were designed to work with the normal string sets of the day. Typically, .012 to fifty something, flat wound with a plain G. (Hence, the rod magnet pole length "stagger" of the Fifties pickups.
    The vibrato springs were intended to balance with the string tension load of what we now call Medium gauge.
    Ernie Ball custom gauge strings were introduced in 1962. Before then, to create a lighter set, guitarists shifted every string across by one and added a plain banjo string for high E.
    With five springs fitted, the "claw" does not need adjusting anywhere like as far towards the far end of the spring cavity.
    IMO, Jeff Baxter advocated a Stratocaster with a stiff set up to encourage tasteful/musical application of wobble and discourage stunt techniques. (Just a hypothesis, folks.
  • guitars4youguitars4you Frets: 14245
    edited June 2022 tFB Trader
    A lot of crap - When Leo invented the Strat he never intended for it to be played the way it is today, often with lighter strings - As such set it up for you and your own style - SRV, Hank, Jimi, Beck and Eric for starters employ a totally different set up and I don't see any of these as wrong
    0reaction image LOL 0reaction image Wow! 8reaction image Wisdom
  • BigPaulieBigPaulie Frets: 1101
    Banjo string!  =)
  • merlinmerlin Frets: 6684
    Banjo string!  =)
    Yup, for a banjo string you need to use springs made of meteor trails and stardust.
    Balance it up with strings, claw distance and as many/tenser/lighter springs as you need. Jeff "Bunk" Skaxter has a dogma because he likes to have an opinion. Some people do that.
    Believe in a God who sits on a cloud, has a massive beard and hates homosexuality. Makes as much sense.
  • swillerswiller Frets: 1211
    I think leo intended to allow versatility. Cue the debate, which way to config a 3 or 4 spring.
    Dont worry, be silly.
  • TeleMasterTeleMaster Frets: 10209
    I'll do what I want thanks. :)
  • maltingsaudiomaltingsaudio Frets: 3127
    edited June 2022
    I think, gentlemen, experimentation is the key, to find what works for you. Leo would have approved of this method, he gave you the tools to find your own way.
    www.maltingsaudio.co.uk
  • robertyroberty Frets: 10893
    A lot of crap - When Leo invented the Strat he never intended for it to be played the way it is today, often with lighter strings - As such set it up for you and your own style - SRV, Hank, Jimi, Beck and Eric for starters empty a totally different set up and I don't see any of these as wrong
    Yeah exactly, the pickup poles were even staggered for a wound G. Silly billy
  • WazmeisterWazmeister Frets: 9534
    Nah, 3 springs for me thank you waiter.
  • DanDan Frets: 441
    Raw vintage springs will let you have five springs and still wiggle like it has three normal springs. Dare I say sounds ‘better’ too.
  • ZenOvertoneZenOvertone Frets: 234
    Same here, RV springs have lower tension
  • grappagreengrappagreen Frets: 1343
    What a load of twaddle..
  • LewyLewy Frets: 4205
    So...what's the point? Fewer stronger springs, more weaker springs...doesn't it all just add up to tension which is either the amount you want or isn't, and is adjustable via the claw anyway?
    Or are we saying that once the tension is set so that the balance is where you want it, the number or type of springs affects the feel of moving the bridge from that point?
    edited June 2022
    The extra springs add weight to the guitar, consequently, sustain is vastly improved.
    I've been adding springs to all my guitars, even the non-trem ones and they all sustain for days.
  • axisusaxisus Frets: 28337
    Why would I care what Skunk or Leo do?
    My preference is 2 springs, although in a moment of sheer madness I went to 3 a while back and barely noticed the difference. It's been traumatic ....
