Hi guys - I'm going to need to expand my pedal-board to include a noise gate to tame hum/buzz - particularly with a USA Standard Strat or Tele with single-coils.
I know there's the Boss NS2 (circa £60-70) but I don't know how good it is or if there are better 'compact' size pedals to go for, so would value your thoughts/experience here!
Cheers
Rich
MXR Smartgate. Covers everything I can think of. I got mine used for £75 IIRC.
More flexible and (IMO) betterer than the Boss.
If you're torn for quality, the isp is great for most gating needs. The mxr smart gate is good, too, and easy to set for general noise reduction.
I think the decimator is better than the boss, but you can only cut one of those things at the same time, whereas with the boss you can do both. for less money. and the g-string decimator (which i think can be used the same way as the ns2, but i could be wrong) is even more again.
CS3 is notoriously noisy too as noted above. The Monte Allum Mod is great for GE7's too.
That's exactly why I got a Smartgate. If you set it correctly you'll remove the noise and hum, but not the quality of the notes (if that makes sense).
I found the Boss best for whacking a massive dirty pedal infront of, and palm-muted chug with a heavy gate (Ala Pantera).
Re posting pedals, if you pack them sensibly you should be able to send 1st Class Signed For - for £4.30 each way.
Modding pedals would reduce the noise - the eq is notoriously noisy, and easily modded with different components. I'd start there.
Eq pedals are almost always noisy stock, too, so replacing it with a "better" one might be false economy.
Many thanks for all the responses guys - definitely food for thought re possible solutions. And Bidley, thank you too for the NS2 offer - not quite sure which way to jump at the moment, but I'll let you know.
Cheers guys
Rich
As a follow up I've been reading various reviews and looking at you-tube clips. I've come across the Behringer NR300 that I can buy new with free delivery from Amazon at £16.99. I have a Behringer EQ900 and To800 that are both really good, and a lot more rugged than you might think.
Forgetting the plastic vs metal case construction, in as far as what this does as compared to say a Boss NS2 (retails at circa £65) is there any real difference re functionality and effectiveness?
