i watched a video on "getting the most ouf of your gear" on the tube...and the guy did something very practical...he hooked up his guitar to a Ditto looper into the amp...played a riff utilising all the string and a few different positions on the neck, with the EQ set at noon...then he let the loop play...put his guitar down, and adjusted the knobs...i never thought about doing that, it would make the whole process so much easier!
I've got one of these. I think I'll look it out
http://www.drzamps.com/amps/carmen_ghia/
Nil Satis Nisi Optimum
Close but no cigar my friend. You put "bookshelf" hi-fi speakers on stands to raise the tweeter to ear level. Spikes are used (1) to ensure that the speakers are vertical [plus or minus absolutely nothing] and (2) to provide a one way energy sink [from speaker to ground]. The positioning of hi-fi speakers is critical to the sound you hear, thus spiking them prevents them being moved easily. IMHO guitar speakers have little in common with hi-fi speakers. Apart from operating using the same principles that is.
I just turn them until it sounds good. On some amps, it sounds good everywhere near enough, so it's not really worth worrying about.
Even on a picky-to-dial amp, it doesn't take long.
The hardest was the mesa mark. It has two eq's but once I understood that one was pre distortion, one post, it was still quite easy.
