In addition to the "tone is fingers" thing, one of the main components of a good sounding amp is the guy twiddling the knobs
I'm a man of limited patience which makes amps like the Mesa mk iv difficult to get what I consider a good sound from. I've heard other people get them to sound great but Jesus there are just too many controls! I tend to start with amps in the 12 o'clock position as I (incorrectly as it turns out) figure this is what the manufacturer wants you to hear
So ....
What are your top tips to wrestle a good tone out of an amp?
You will LOVE this then!
http://www.zzounds.com/item--BLCS200W
Dave.
start with the eq controls at half way, then starting with the low end go from minimum and increase until you hit the sweet spot for that frequency band. then go on to treble, then mids etc.
For example when adjusting the bass control, I'd start with it all the way down, and play open palm muted repeats on the E/A strings and bring up the bass control until I get the amount of bloom and low end response that I want. I often find this is around 3 or 4 on the dial.
I don't really have any particular method, other than to just listen to what all the knobs do over their full range of travel and experiment to find the best combinations. Sometimes it can be a pain because it changes with volume.
That and turn the bass up full, of course.
If you use their recommended settings as a starting point they dial in pretty easily in my experience. If you take the 'everything at twelve o'clock' approach, they will disappoint.
Bass on full - that's where the depth and space is.
Mid on zero. That's where the boxiness and harshness is.
Treble on wherever it sounds right - usually above halfway somewhere. That's where the sparkle and cut is.
OK, that does work best on an amp which is middy in the first place, but most guitar amps are. And it's really a starting point rather than a final setting, although it's rare that I turn the bass down unless the amp is too boomy.
Yeah I don't agree on the whole mids thing. It's fine to scoop the mids, it's fine to have balanced mids too. Most touring sound guys I've worked with hate the boosted mids thing, yeah you'll get heard but you'll also cloud the vocals, cymbals and upper bass stuff.
I generally find the bass is below the bottom end of the guitar even when the guitar amp has the bass up full, which is actually more of a low-mid than real bass. (This is generally not boosted, just not cut - active EQ makes this less of a good idea.) I also like to physically raise up the guitar amp, which rolls off the bottom octave to a large extent - then with the bass amp on the floor, it literally sits 'under' the guitar.
There are no real highs in a guitar amp - they don't go above upper mids, because a guitar speaker can't actually reproduce real highs. Whatever you do the cymbals, top end of the vocals and any acoustic instruments will go higher and should sit over the top - although bad vocal mixing to fight feedback sometimes prevents this.
I think of live mixing as like a fruit trifle (bear with me ) - if you make a graph of all the frequencies with the instruments on top of each other, they should roughly fit together so the total level at any frequency is about the same... like a cross-section through a trifle .
So the bass should be very deep, but can also have some highs in it (hence why modern bass amps often have tweeters). The rhythm guitar should be scooped, with low mids ("bass") and high mids ("treble") up and mid-mids cut to fit inside that but still leave a scoop in the middle, which is where you want lead guitar (which needs to be mid-boosted and bass/treble cut) and vocals (which need mids for intelligibility) to fit - these two generally don't want to be there at the same time. The drums are a fairly scattered mix of frequencies but are discrete events within the mix rather than continuous sound, so they're like the fruit . Then on top of it all you have the cymbals and things like tambourines and shakers which are like the sprinkles...
I actually find that sounds which work well at home can work well live as well - particularly rhythm ones - provided you don't overdo it. You just have to be aware of the context and always mix with your ears, and not just turn the mids up to "cut through", when what you actually need to do is *fit in*. It also works better with big amps than small ones, the correlation between low and high volume is much closer - small amps tend to go muddy and harsh if you try to push the bass and treble up.
Where exactly doesn't seem to matter that much.
Amp positioning is important too. If you place an amp on eg a carpeted floor you'll lose some tone and volume into the floor.
But if you're struggling to get the right tone from just using the amps eq I thoroughly recommend trying an external eq. Depending on your amp this can be particularly effective in the fx loop.
In the whole I'm pretty happy with my tone
But I never turn down the opportunity to put my ego in my pocket and learn something new
Lots of stuff here I'll try, some I'll keep some I'll throw away but a great opportunity to benefit from other people's hard win experience.
Good forum this. Lots of knowledge
I like it on the floor where I can push it harder but taking the directionality of the speaker away
But then that's a 1x12 combo
I like the dispersion and tone of a 2x12 but things like the Matchless are just too loud for most of the venues (although interestingly enough ICBM prefers a big amp running quietly so I might revisit that)
Eqd Speaker Cranker clone
