Right here's the plan, set neck tele with lp control layout 2 mojo pickups p90's.
Body and neck is limba, fretboard is figured madagascan rosewood.
It's having a schaller signum wraptail bridge and schaller open gear grand tunes with rosewood buttons
I've already cut the body and neck out, it's having our own angled headstock, same as the strat we've just done, you can see it in made in uk thread.
2 way truss rod and 50's style lp carved neck
I'll see if i want binding on the body and i'll probably contour the body and neck so it's more comfortable.
www.danielsguitars.co.uk
(formerly customkits)
I cut some ebony dots for it too then i bound it with the madagscan rosewood, which i'll show next time
I did the p90 template today.
The body already has the switch cavity done and the mortice is mostly done but not full depth, i need the bridge to work out height.
The templates are so we can use these for the 2 f hole thinline we did or a solid body version, you can see the thinline pic in made in uk.
I got a quick demo of it today so that'll go up next week hopefully.
I don't think i'm having a cap now, it depends how light i want it, if it's heavy i'll chamber it and put a cap on.
It doesn't look that dark when it was finished but I really liked it.
thats why the controls are where they are.
I made the p90 routes both sides so i can easily do left handed.
flat on the body.
Fret the fingerboard then do the p90 routes.
I'll get the headstock veneer on and shape it then drill tuner holes, it's coming along nicely.
The limba is a really nice weight.
