For the amps, I'd recommend as a first one, a digital modelling one to give a good variety of tones. There's about 5 different makes/models all competing in the "consumer level": Line 6 Spider V, Boss Katana, Fender Mustang, Vox VT series, Mashall CODE series. If you don't need a high power level, then the lower models in the 20-30W range are quite affordable. The Line6 and Boss amps are quite new and since these things are somewhat rapidly developing technology, the newness is definitely worth checking out. Most of the amps also include effects too, so it would save on buying any of these initially until you know what you want etc.
These are just example prices:
Squier Standard Strat: £278
Line 6 Spider V 30 Watt: £170
That leaves a little left in your budget for lead, strap, gig bag, etc.
Used CV Strats and Tele's are common, often selling for around £200-250, maybe less if you're lucky (people often sell them on eBay as a Squier, not knowing they've got a CV) - These are much better than a new Squier Standard, and in my opinion probably better than most Mexican Fender's too, plus the added bonus that the CV line comes in great vintage colours. I picked up a Squier VM for £60 recently from an eBay'er that thought they just had an average Squier.
Amp wise, a used THR10 will be anywhere from £160-180 and are a great option, lots of the new modeller's are much better than what you could get in years gone by, but I'm always pro buying used, so that if and when you sell on in future you don't lose any money. I just picked up a Fender Mustang III v2 for £130 to use as a speaker for my Kemper, but it's pretty good as an amp in its own right too.
Any money you have left over is either a bonus to spend on something else, or you could get a pro setup done on the guitar, for peace of mind, as someone who is alien to electrics. A properly set up CV Squier will be a much nicer guitar to play than a new Squier, which wouldn't be setup as well from the box as a pro could do.
Ennspek - something that'll make me play just like this will be great
£500 is more than enough to get you a very decent starter setup. By all means listen to the suggestions you get from the forum, but believe me when I say that there's absolutely no substitute for going to a shop and playing a bunch of guitars to find out what you like.
If it were my money, I'd probably go with something similar to what others have suggested- new or used Squier and an a digital modelling amp- whichever you find easiest to work with and/or best sounding.
- much like when I bought my acoustic I want to buy the best I can afford at the time so that in a couple of years I don't feel like I've outgrown it....I'd like something I can age into comfortably so maximising value for money is paramount....hence being more than happy to buy used.
- and regards the amp, quality of sound at low volume is a really important factor, but I'm guessing that at my price range, it's much of a muchness?
Amp - I don't recommend a valve amp for your first amp. Tonally it is more restrictive, with no effects built in (you might get reverb), and they (normally) can't be used with headphones. You need something that gives you lots of tonal options to experiment and have some fun with. Replacing tubes can also be fiddly and expensive.
You could do a lot worse than the Fender Mustang I v2 or Mustang II v2. This is a solid-state (no-valves) amp that broadly models the tones from famous amps and effects. Light, compact, headphone for quieter practice at night, no valves (aka tubes) to worry about replacing, easy to use, good tone, built in effects, 2 yr Fender warranty in the UK, and you can have lots of fun with it, Store prices are typically £105 for Mustang 1 or £148 for Mustang II. The II has a bigger, better speaker, more volume and should be loud enough for band practices and small club gigs - the smaller Mustang 1 is still pretty loud but is probably more for just home playing.
https://www.andertons.co.uk/p/2300104900/combo-amps/fender-mustang-i-v2-1x8-modelling-amp-combo
https://www.andertons.co.uk/p/2300204900/combo-amps/fender-mustang-ii-v2-1x12-modelling-amp-combo
Guitar, I recommend something that gives you both humbucking and single coil tones. This is your first electric guitar and its too restrictive to opt for an all single-coil or all-humbucking guitar. Humbuckers give a fatter, darker tone that distorts easier; single coil tones are brighter but are bit thinner (less full) sounding. This is a learning journey, and it's all about experimentation with tone & feel. As your electric journey develops, then you can choose something more specific for your needs - but right now you don't know what these are.
Depending on what your musical tastes are, you may want to think about whether to opt for an electric with a tremolo arm and floating bridge (where you can move the arm to 'wobble' the pitch like Hank Marvin, or a 'hardtail' which can't 'wobble' , A tremolo gives you some extra musical options, but can be less stable tuning wise and some types can be a bit more awkward to string and set-up the guitar properly. Unless you really want a tremolo, I'd suggest you stick with hardtail for your first guitar - less to worry about.
For a first guitar that's easy to play, with easy access to the higher frets, light weight, with decent humbucker and single coil tones, I'd suggest you can do a lot worse than the Epiphone (made by Gibson) SG Pro, £299 from main stockists.
https://www.andertons.co.uk/p/EGG4CHCH1/solid-body-electric-guitars/epiphone-g-400-pro-sg-cherry-chrome-hardware
If you buy both amp & guitar together from the same supplier, you should be able to get a guitar strap, a lead, and/or a set of strings and a pick or two thrown in too or at least discounted.
If on reflection you don't want to spend quite that amount of money, there are electric guitar starter packs available e.g.for £240 you can get this - the Affinity Squier guitar is made by Fender and has both humbucking and single coil pickups, and a tremolo, and the amp offers a range of tones plus some built in effects, and things like strap, lead etc are all included:
http://www.gear4music.com/Guitar-and-Bass/Squier-by-Fender-Stratocaster-Pack-HSS-15W-Amp-Candy-Apple-Red/L81
Hope this helps, and good luck.
It gives you the 3 basic amp sounds and is very easy to use.
I'm not sure a modeller with dozens of options is a good idea, you might spend more time fiddling with the amp than actually playing.
Guitar-wise: any of the above recommendations.
I find amps more difficult to get a feel of in a shop, if you're planning on using headphones take them with you- many amps doing very different out loud vs through their headphone port.
I have a Thr 10, it's probably the single most used piece of guitar kit I've ever had: it sounds good, is versatile and looks good (meaning its always out & ready to use- some guitar amps are fugly).
Pacifica guitars by Yamaha are worth looking into. They are excellent in terms of build, versatility & value etc, however the necks are quite slim. This can be divisive. The higher the model number the higher in the range it is. I'd try a 112.
Good luck with your choosing & remember that we NEED pictures when you have something!
If you know someone who already plays, I'd recommend using their experience to find a decent guitar. Nothing is more off-putting than a guitar which is really hard to play.
The good news is that there're are loads of decent used guitars about at good prices. You can upgrade pick-ups, or move it on without loosing money if you buy wisely and subsequently want to upgrade.
http://m.guitarguitar.co.uk/Product/PXP161023303125002-490180
And this
http://m.guitarguitar.co.uk/Product/160907302101008
Thank me later
http://www.richtonemusic.co.uk/products/blackstar_ht-1_r_combo_w_reverb_1w_tube_guitar_amp-_ex_demo.asp
Nil Satis Nisi Optimum
1. Both humbucker and single coil pickups
2. A neck profile which lies between Gibson and Fender
A Pacifica into a Yamaha THR amp would be on my short list to demo (if buying new).
Agreed with everyone here: play whatever you can, wherever you can find it - IMO stay away from the "boxed-wine" quality guitars i.e. starter kits or anything less than £180 or so new, because while you can find gems below that pricepoint, everything above it is typically serviceable.
I went into guitar with the same idea as you (quiet, headphone, etc.) and that's still important to me now, but please don't underestimate the joy of playing through a 1x10 or 1x12, it's a whole new world.
