I'm using my usual preferred type of strings not the ones included in the kit. I imagined certain stuff included within the kit would not be ideal so I was prepared to get my own parts for something's like strings tuners and pickups. What I didn't expect was for essentially every part of the kit to be rubbish including the neck body guard and electronics
My main criticism of this particular kit (though it can't be the same for all others) is that the only thing shitter than the kit and constituent parts is the manual which has consistently been wrong or misinformative.
For anybody looking to get their first kit guitar do NOT buy a Stretton Payne brand one. I cannot reccomend it lowly enough
soundcloud.com/thecolourbox-1
I've broken another string tonight fiddling about with it, but what I've done is tune the ones I've got up correctly, then fretted each note with the tuner on and listed how far out each fret is on there. My tuner has bars either side of the exact note so for eg +4 means it's sharp, -2 means it's flat and so on. Fine it on 1st 2nd 3rd 4th 5th 7th 9th 12th and 15th on the for remaining strings:
http://i1287.photobucket.com/albums/a639/matthew_goodwin1/Mobile Uploads/IMG_20160219_221303_zpszw0zgb28.jpg
Interestingly as you can see from the 7th fret upwards all is fine, then things get worse and worse the closer to the nut you get. I'm not too concerned at the -2 on the 15th fret on the D string as that probably just needs a quick screwing one way or the other, but the predicted pattern is definitely there.
So then, let's see if I can find a good way to sort the nuts, I'm guessing I'm going to need lots of patience here to get it right. Which is a problem when I'm the last patient person you could ever hope to meet but needs must
It is best to lower the slots rather than sand the bottom, but its tricky without proper files.
I have proper files, but tried a totally DIY method for the kit guitar challenge a couple of years back. I cut up a beer can into strips and folded 240g wet & dry paper around the metal shim. It wasn't perfect but did work.
The welding cleaning tips may work here too, especially if its a softer nut(quite likely on a cheaper kit)
The only answer for pro results is proper files
Instagram
I've resolved to try and get a new pickguard made to measure because the one I've got is now useless, quite how I'll do the template for that is a different question (and thread) but that's the only option at this point I think.
I'm going to try and put different strings on it before investing in the nut file, in case the problem doesn't occur with slightly different gauge strings.
I don't know what the seller will come back with, or whether there was even any point in my complaining - I've has to spend quite a bit of money on getting the instrument even to this stage so I'm kind of invested in it, but I'm still quite bitter about buying it from then rather than other manufacturers who don't seem to have such quality issues (and in the case of Thomann probably would have been cheaper as well!!)
Happy to take a look and do you a plug and redrill on the bridge/neck join FOC... But as you know, it wont be speedy.
Instagram
The wood looks nice but that could be done on anything with my leftover dye, and to be honest it doesn't look as nice as some of the wood coloured thinline Tele guitars you seen to be able to pickup very reasonably which I would probably target as a replacement
The lovely Lady seems to be OK with that, if I can manage to find somebody interested.
When picking up my Airline, I took this little fellow with me as well to see if anything could be done. Turns out the neck needed "shimming" which I hadn't heard of before. I think it means putting thin bits of wood underneath the neck joint to change the angle just slightly enough to get the bridge in line. I'd never have known about that let alone thought it might be needed!
The pick guard needed a bigger reamer than I had, but that was reassuring in a way because I had been trying the right thing, just didn't have the right stuff.
Once the whole had been sorted for that, the bridge screw in bits then fit through so for later adjusting it would be a case of raising it up, rather than having to go to and down on that.
The nut issues previously discussed and advised on here were correct - the grooves fur the strings were way too high so once the truss rod had been fiddled with, the grooves were filled down a bit.
So all I have left to do is slight adjusting on the intonation or action as I've not checked for any buzzes yet, soldering in my switch (those wonderful solderless eng pickups are not as solderless as they'd have you believe!) and then screw in the truss rod cover and the back cover over the electronics
From the brink of defeat...success may yet be reached*
*totally only because Wez did the hard stuff for me
Instagram
http://i1287.photobucket.com/albums/a639/matthew_goodwin1/Mobile Uploads/IMG_20160417_102644_zpsyvoixozk.jpg
Though the wood looks a bit lighter in photos than it does in person
