Took this monster out on Friday night, there was hum
There are many more things than I need on it, but some work with different amps/guitars and it's easier to have just the one board really.
It's a Harley Benton spaceship 80 with a Donner DP-3 powering it all
I have to confess that it does amuse me - There are currently (I think) 13 power supplies (mostly cheap chinese ones bought from Amazon) plugged into 4 multi-plug extension leads with numerous daisy chains in all directions. With no pedals switched on but with the amp on and a guitar plugged in there is a small amount of noise at the volume I record at, but you have to put your head against the amp to hear it.
It is basically one long 35 pedal chain, apart from the Miku which is plugged into a feedback looper pedal.
The RC-50 isn't plugged in at the moment but I am planning to use it at some point.
It is ridiculous, but that's part of the fun for me
http://i65.tinypic.com/mlnrso.jpg
Its good to see/hear that it isnt a problem in having that many pedals all chained.
I’m guessing there are buffered pedals in that lot, but can you say you notice any cable related tone suck vs direct in?
I did run a test with a mate listening and IIRC the only noticeable difference was a slight drop in volume, but I can't remember which was which now
Very nice thing it is too.
https://i.imgur.com/zGl8tFY.jpg
Some gigs don't need a wah so I'm happy to have that off the board.
95q, centura klone, kot, ethos od, el cap, dm2, flint.
dm2 is on all the time with a quiet slapback and el cap for longer delays, klon for a lead boost at the moment with the kot for low gain but I might swap that when after I've gigged it.
way too many colours for me, but still pretty good.
