http://www.youtube.com/watch?v=PQOKh_AhgGc
http://www.youtube.com/watch?v=LzdeN8n9n64
Agree with this, I have played alder 60's tele's that sounded fat as hell early 50's that were Ash and thin, not sure exactly if anyone can say which is which, only that they can hear a difference.
Have look at link’s below. The first guitar is a Tele but built as a LPJ I’ve made a lot of these and the one thing you can be sure of it does not sound like a Tele but just like a LPJ. I also build a lot of Tele’s with a Mahogany body with a Maple /Rosewood neck HB at the bridge SC at the neck. Sound wise bridge P/U almost a LPJ but not a Tele, the neck P/U single coil still not a Tele sound. The second guitar in the link is a Alder body Maple / Rosewood neck. This will more of a Strat sound then a Tele.
If I’m ask to build a Tele with a darker sound I tell them there are not many ways to do this and keep the the classic Tele sound. The easy way a standard Tele in Alder or Swamp Ash but with Seymour Duncan Quarter Pounder pickups. The bridge has a coil tap so full on almost a HB but when coil tapped it takes on a glassy hot Texas sound. The neck P/U sound is a bit heaver then a standard Tele neck PU. If you then add a 4 way switch you will have a guitar thats a Tele and and almost a Les Paul will nearly. There are more ways to do this but this way works really well, although have a look at the second link this is my Tele built with Bare Knuckle PU’s and a 4 way switch not as heaver as the SD pickups but add’s a bit more to the Tele sound.
If you go Mahogany then you will lose some of top end glassy twang.
http://www.thefretboard.co.uk/discussion/13333/lpj-come-tele#latest
http://simnettguitars.co.uk/forum/index.php?topic=3708.0
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
