phil_b
Frets: 2015
so there are many low cost Chinese made products available from various sources. some turn out to be not fit for purpose some ok but poor quality and there are some real gems out there.
ebay, ali express , and wish have so far been my favourite websites for such purposes.
I am very much a beginner guitarist and spending loads on high end gear seems to be a waste for me as I am just experimenting.
I have been very happy with my biyang OD-8 and ammoon looper pedals. I did buy a daphan delay pedal that I was disappointed with as although it worked the delay available was not very long.
The main disadvantages of buying direct from china is you cant try before you buy and have to rely on some photos and short description or you are relying on a youtube review. Also returns are normally not worth the effort of even to bother to try.
what gems have you found
LOL 0
Wow! 0
Literally no downsides to getting one. Mine swaps in and out of my board as an always-on boost alternative to the ThorpyFX Heavy Water, when I just fancy a different flavour.
delivery time does vary. smaller items don't tend to take long. The longest I have waited was 5 weeks for a guitar neck. The neck was one of my disappointing buys. it was ok but the headstock was a lot smaller than I had imagined going by the photos. the neck was ok it was just one of those items that I would have passed on if I had seen it in the flesh first.
I don't remember having to pay anything extra on an item direct from china on arival
I've got a Biyang Baby Boom reverb pedal ..... cheap as chips but it's lasted a good hundred gigs so far despite all the beer that's gone over my board due to pissed people falling over the monitors
I've currently got 4 cheapies from diff manu's I'm rebuilding. 2 were black and white strat copies - 2nd hand <£99 jobbies, one HSS and my new Harley - these are my conclusions;
https://flic.kr/p/2i8LRyH
Harley Benton std Tele - Looks well made, no defects which some customers (used to?) get, had a QC pass from "Alan". Looks & sounds really good, good tele twang and sounds pretty awesome on the bridge with a bit of Supercrunch! I'd highly recommend it for £85 to your door, only a few weeks old at the moment but v. happy so far!
Encore Satan 666 - neck looks good on this one, can tell it's more directed to the shredders, I think these were more than the sub £100 ones mentioned here but tuners look a bit naff, body was very thin at the routing, broke it trying to get some screws out and was unable to play it as it needed wiring. Jury's out on this one but as it was more I'd expect it to be a bit better in places.
CB SKY Strat copy - cheap tuners, prob worst of all of them, string trees on too far over which pulled the nut off to the side so it was hanging off. Pickups sounded awful, very distorted all the time, not sure if poor set up or poor pickups causing bad sound but likely both and not good if you have to fork out for someone to set it all up for you. Rear routing doesn't seem deep enough for the parts, I had to file bits of metal and wood - changing pretty much everything on this - prob only good for a project if they're all like that!
Burswood Strat copy - really quite impressed (but not the 10w amp it had)! Good 10mm tuners so look direct replacements for your Wilkinson upgrades etc, never went out of tune in the 4/5 years I've had it though! Very good pickups for the price, not exactly your vintage Strat sound but made all the right noises when I wanted it too - certainly good enough for a beginner (capped 500's). Pretty neck, cheap nut as rest but never any probs, all aligned with the tree's - in fact the only thing that let's this guitar down is the rear routing which isn't aligned with the neck but apart from that she's a little beaut! Little things I noticed as well like the cutting/placing of the ally compared with the CB for example;
https://flic.kr/p/2i8Mm43
Could be luck of the draw but the HB & Burswood seem to be the best built from those, just a little more care and attention in parts and fitment - all use similar/same looking parts but they just feel and sound better overall. Just my 2p but my advice - do what I did - spend many hours pouring over luthiers vids - get to the local 2nd hand shop and pick up a cheapy for upgrading!
I bought them both off Amazon so didn't have to worry about import fees or excessive wait times.
https://imgur.com/YiSHRau.jpg
First the strat - the bridge pickup route was so large is left about 3mm of space between that and the trem block route. this inevitably split and I had to buy a new body for it.
Then the Les Paul - neck wasn't glued in well at all - at a slightly funny angle and you could see cracks in the lacquer where it was coming away from the body. You could quite easily put the guitar out of tune by wiggling the neck - and not in the way a Tele or Strat does it, I mean fully out of tune.
Upgraded the pick-ups on the Tele to Wilkinsons and it sounds great - I've gigged with it extensively.
The LP Jnr needed a fret dress and replacement bridge and stud posts, I also upgraded the P90 to an Artec one - I've gigged with this one a lot too.
I also have a Hotone Britwind Floor amp. After trying a Helix, and just not being able to love it, I wanted something analog. The Britwind doesn't have a tube in sight, but it feels very 'real' and takes pedals really well.
I recommend Donlis pickups. Fantastic and in my opinion, on a par with Irongear, tonerider etc. I currently have an alnico 2 bucker in my Strat, and it does not sound like a 20 quid pup.
