PSA: New Harley Benton GPA-100
paulphoenixpaulphoenix Frets: 141
edited September 2020 in Amps
£70 from Thomann
https://www.thomann.de/gb/harley_benton_gpa_100.htm
The GPA-400 is fairly well regarded so this should hopefully be a worthy alternative to the lesser liked Thunder 99 (and cheaper too).
Until this I'd been eyeing up a Hotone Loudster.
«1345
  • monquixotemonquixote Frets: 17637
    Looks interesting
    I'm guessing it's a clone of the Seymour Duncan Power Stage amps.
  • I've found the GPA 400 to be awesome. Might give this a try as I don't need that much power!
  • thecolourboxthecolourbox Frets: 9795
    Looks to be useful for what I'm trying to put together, a small power amp in a funky looking cab so I ca use my modelling preamp into it if I need to play in public.
    Looks cheap at £70, half the price of the EHX 44 Magnum. proper kettle lead as well and not one of those noisy laptop style psu things.
    Though I would need to be careful as it's 100w and my speaker is only 50w, d'oh
    soundcloud.com/thecolourbox-1
  • sgosdensgosden Frets: 1994
    Very interested.
    Using a matrix GT at the moment but most the time it's overkill and full rack size is awkward
  • @thecolourbox you'll have absolutely no issues with a 100w solid state power amp driving a 50w 8ohm speaker trust me.
  • @joehindley103 ;
    would that be the same for my 100W 4ohm speaker and the 190watts that this thing belts out?
  • @paulphoenix absolutely. Solid state power into a speaker is not 1:1. If anything typically you'll be looking for double solid-state power to the speaker rating. It's not the same as you would treat a valve power amp and speaker match up.
  • It is crazy how cheap they manage to make things.
  • that looks freaking awesome
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
  • As a GPA 400 user I feel I could deffo use this as a back up
    So who's going buy one and tell us if they are any good?
  • £70! How do they make them so cheap! You could buy two and expect one to blow up a year and it’d still be cheaper than a Duncan power stage. I’ve got no gigs until July, or rehearsals anytime soon, but a small cab and couple of these might make a easy to move rig when I do.
  • HAL9000HAL9000 Frets: 9684
    Does the volume work backwards? Looks like 0dB on the right and the infinity symbol on the left.
    It's minus infinity.
    It's a scale relative to peak power.
    Ah. Missed the minus sign.
  • So who's going buy one and tell us if they are any good?
    I guess that'll be me then.... order placed with Thomann this morning. Check back in 4 weeks for an update.
    Awesome!
  • Thanks for taking one for the team
  • It's minus infinity.
    Can I ask what this means? Why is "no sound" minus infinity, and "effing loud" is "0db"?  Why not 1 - 10 or something sensible?
    It'll be referring to signal attenuation .... But I agree, 0-10 would make more sense to most.
    ...I'll wait till the ones that go to 11
