Weird things you never knew
  • poopotpoopot Frets: 9099
    The KFC Twitter account follows only 11 people…
    the “spice girls” all five of them
    and six blokes called “herb”
  • HattigolHattigol Frets: 8190
    To save everyone else checking this, I just have - and he's right!
    "Anybody can play. The note is only 20%. The attitude of the motherf*cker who plays it is  80%" - Miles Davis
    And… turtles don’t live inside their shells…
    they ARE their shells!!!!!
    0reaction image LOL 7reaction image Wow! 1reaction image Wisdom
  • EricTheWearyEricTheWeary Frets: 16299
    Muppets are usually left handed.
    [Puppeteers are usually right handed so the muppet goes on their right hand and then they use their left hand to hold the stick that controls the puppet hand so that becomes the muppet’s dominant hand]
  • vizviz Frets: 10719
    That turtle looks really, really annoyed about something.
  • sev112sev112 Frets: 2793
    Simonh said:
    Tannin said:
    "I walked out the door."
    "I took the broken glass panel out of the door to put a new one in."
    You will hardly ever strike a situation which requires the "out of" - I had to think up something contrived just for the same of providing an example.
    Adding a spurious "of" to otherwise decent sentences is a pointless and ugly Americanism.
    I made a swan out of a single sheet of paper using origami
    I made a swan out a single sheet of paper using origami
    I made a swan out of paper using origami
    I made a swan out paper using origami
    I made a swan from a sheet of paper
    england scored two from three penalties
    ”out” is the odd word out in the various examples.  Adding of to it, is a consequence of poor use of the word “out” in the first place
  • rogdrogd Frets: 1514
    Gordon Bennet!!
  • Emp_FabEmp_Fab Frets: 24428
    You missed a 't'.
  • hollywoodroxhollywoodrox Frets: 4206
    This thread is descending into silliness , I really wanted to know things I didn’t know, it’s very interesting
    If you mined all the gold in the oceans, there would be approximately 4kg for each person on earth.
    Emp_Fab said:
    You missed a 't'.
    t
    It’s impossible to hum whilst holding your nostrils closed!.
  • bobblehatbobblehat Frets: 541
    Thats nuts!
  • KalimnaKalimna Frets: 1543
    poopot said:
    If you strap a slice of buttered toast to the back of a cat, butter side up, then drop the cat/toast combo from a height… it will drop to about an inch off the floor and then just spin continually!…
    Many years ago, New Scientist magasine ran several letters on such a theme. It was then posited that the sound of spaceships humming was, in fact, multiple banks of toast/cat engines all spinning simultaneously.......
  • droflufdrofluf Frets: 3742
    Of course that would be useless in outer space because the toast/cat engines need gravity.
    I suppose the spaceships must use a different type of engine for interstellar travel.
    Spoonfeed is the longest English word with its letters in reverse alphabetical order.
    1reaction image LOL 1reaction image Wow! 1reaction image Wisdom
    Ahhh, but you will also have noticed that folks on spaceships manage to walk around the decks courtesy of an artificial gravity field. However, I remain uncertain what powers this field, nor what should happen (inertia perhaps?) to the spinning cat/toast array in the event of gravity field failure :)
    Adam
  • the_jaffathe_jaffa Frets: 1808
    And on a related note:
    "facetious" contains all of the vowels, bit only once, and in order
    One of my favourite facts; there are a bunch of others such as adecticous although facetious is probably the only one you might use in every day conversation.
    Very much enjoying the spoonfeed fact and looking forward to using it ( someway, somehow).
    A duel between three people is called a truel.
