BOSS SD1 Super Overdrive. Good or Not?
13»
  • HAL9000HAL9000 Frets: 9718
    markj said:
    Would it suit Fender amps?
    In my opinion - definitely.
  • vizviz Frets: 10710
    They’re close to perfect really.
  • prowlaprowla Frets: 4936
    The SD1 is a great pedal.
    Somehow, I seem to have two of them.
  • TTBZTTBZ Frets: 2910
    edited August 2021
    SD1s are great for boosting a Marshall my byoc tubescreamer is finally showing signs that it's on its way out, it's probably just the switch but I'd rather move to a Boss style switch now anyway so I'll be getting a dirt cheap SD1 soon.
  • markjmarkj Frets: 914
    What about the SD3 are they smoother?
  • ICBMICBM Frets: 72514
    OD-3? Yes, smoother, and with a bit more bottom-end. But also with massively overbearing blandness, for me! I just can't find anything to actually like about them even though they don't positively sound bad - just MEH. The SD-1 has much more character and attitude.
    Others may disagree...
    I loaned one recently at a practice  - seemed quite noisy - is this normal ?
  • TimmyOTimmyO Frets: 7528
    no more so than any other medium gain OD - maybe the venue was giving off noise and the pedal just accentuated it, or were other pedals behaving better?
    Red ones are better.
  • SupportactSupportact Frets: 980
    I wouldn't say the Sd1 is particularly noisy. Not more than other overdrives, obviously more noise if you have the gain up high.
    I'm at a different venue on wednesday n will check it out again at a decent volume  - I didnt have any other gain pedals with me ... but will try in different amp n take some other drive units to check the comparable noise levels
