Solo of the Month (SotM) #77 - Challenge
  • Managed to send mine last night.
    It's in the playlist.
    It's not a competition.
    Love it !
  • OMG - this is going to be a bloodbath - fantastic entries - loads of harmony stuff - all the toanz, and whammy stuff.
    I'd better get the Hamer Ukulele out...
    How long have I got to do this thing?? - not long enough by half, thats how long!
    * Hamer Watson, SS2, Vintage S, T62.
    * Music Man Luke 1, Luke II
    Please drop me a message.
  • Niiiice @Bellycaster :+1:
    This one goes to eleven
    Trading feedback here
  • Cheers, lads. I blush with modesty  =)
    Bloody fingers hurt after doing that one.
    Only a Fool Would Say That.
  • SpringywheelSpringywheel Frets: 942
    edited December 2021
    Sent mine in. Great backing track maharg, I had fun with this.
    fastonebaz said:
    I even broke a string getting into the "feels". Doh.
    You and me both....you'll probably hear on mine the moment I switched from Jag to Strat towards the end
  • Sent mine in. Great backing track maharg, I had fun with this.
    I can't remember when I last broke a string. It must be years ago. I obviously need to put a bit more effort in.
  • Done mine. Trying to play slowly this time (hence the spin on the backing track title) :)
    Here's a warts and all video.
    That geetar has such a juicy tone I love it.
  • fastonebazfastonebaz Frets: 4115
    Sent one in.
    My approach:
    I wanted to focus on riding the volume with as least gain as poss,  playing as cleanly as I could, and initially pinching the string between pick and thumb to twang it and build up the intensity across the track
    Once I'd worked out the structure of my piece I decided to start with neck pup volume on about 1.5.
    As I got to half way through I nudged neck volume up to 5 and flipped to the mid position hastily but incrementally upping the neck volume to 10 with the playing getting more frantic until I reached the end at which point I wanted to select the neck pup again and wind the volume down to 1.5 for the final E major chord strum but in the excitement I only made it down to about 3 so the final chord isn't quite as clean as I was aiming for.
    Practised it loads but this was the first and only recording I took.
    Overall quite pleased with the feel of it but there are a couple of bits that could've been a bit neater.
     relieved
    My high E unwound at the bridge,  I reckon it must've been a faulty one.
    Jaguar / Stratocaster
    Kingsley Constable
    Laney L5 > Torpedo Cab
    Valhalla VV in FL Studio
    The idea behind mine was to keep it pretty minimalist.
  • Sent one in.
    It's in the playlist. That makes 6 entries.
  • And one from @Bennyboy-UK in the playlist.
    That makes 7.
  • Bennyboy-UKBennyboy-UK Frets: 1727
    My entry is on the way
    That was a tricky one for me - and I'd tried a totally rich effected clean tone previously to try and use that - but I was killing myself with rerecording it, so I banged this out this morning instead - and I'm happier with it all round - phew - glad thats done!
    1991 Hamer Centaura Custom Order (Solid figured Maple Body and SD Parallel Axis set (PATB-1, and 2x PATB STK) - Fractal FM3 on a Boosted Bogner Blue Model, with two IRs - one 4x12 GB, one 2x12 JC Combo), CE-2 Chorus Model, in to parallel stereo Tape Delay and Dual Detune Pitch - panned Land R hard across all of them, then finished off with Medium Plate reverb Model.
    Bridge HB with about 30% treble rolled off on the guitar.
    One thing on the track that was really hard in my brain is that it ends before resolving to the E.
    so I decided to try something to imply the resolution at the end using the three note motif from earlier but with natural harmonics and slowly dive-bombshell the second one to point to the E and just decay….. you can hear the trem springs creaking - poor old thing
    The FM3 IRs even on standard quality are great for the length of cab decay. This was a test of that and I was really impressed.
    Happy to share any licks anyone is interested in
  • stratman3142stratman3142 Frets: 2201
    In the playlist.
    Very nice guitar, but did you have to prop it up on the sofa with your underpants under the headstock? :)
  • I had considered using pants!
    that’s actually my jumper :) a bit less grippy !
    In the playlist.
  • HabaneroHabanero Frets: 254
    I once had a wound D-string snap. It went with such a bang that initially I thought the bridge had broken.
  • This is gonna be a hard choice on the voting !
  • I really like the backing track but I've been struggling with this, must have made about a hundred recordings so far, trying different approaches, but getting very frustrated with my timing and phrasing, the slower pace really highlighting my errors. Trying now a more textural approach, will keep at it.
    That was epic @Bennyboy-UK  I like how it ends with the whammy down to the root note.
