Wordle?
  • sinbaadisinbaadi Frets: 1312
    I only get the one per 24hrs.
     I did today's at about 12 minutes past midnight with an infant in my arms, and my next goes live in 6hrs 50 mins at time of writing.
    Also my solution did not have any repeated letters today? @littlegreenman ;
  • In 4, forgot it can use letters twice!
    That's what catches me. Often when a letter is repeated, I'm on a 4 or 5. With no repeats I'm usually 3 or 4.
  • EricTheWearyEricTheWeary Frets: 16300
    Does seem to be every 12 hours for me yet reading online it says every 24. And is supposed to be the same word every 24 hours.
    May just be further proof of me losing my marbles.
  • I've restored my batting average a bit today. Got it in two, despite only having 1 letter correct on first go. Happy with that
    soundcloud.com/thecolourbox-1
  • Four today. A less commonly used letter threw me.
  • Tricky today.  Took five; four goes before I hit a single green.
    Trading feedback | How to embed images using Imgur
    As for "when am I ready?"  You'll never be ready.  It works in reverse, you become ready by doing it.  - pmbomb
  • Four for me.  Yes tricky today.
  • stickyfiddlestickyfiddle Frets: 27219
    Tough today. Got it in 5 but that successful one was a bit of a gamble
    3
    I always start with the same word and nearly got it in two so probably need to change my start word now!
  • mrkbmrkb Frets: 6915
    In 3
    Karma......
    Ebay mark7777_1
  • springheadspringhead Frets: 1602
    4 today. An improvement on yesterdays 6!
  • sev112sev112 Frets: 2795
    Anyone noted you can increase the difficulty by forcing having to accept the clues, ie you must put greens where they are shown, and use the oranges on all subsequent words.  Might start trying that from tomorrow, really buggers up my technique
  • ShrewsShrews Frets: 3049
    Three days and a 3-3-6, so chuffed with that.
    Best starter word?  My nomination would be Audio, with four separate vowels and a common consonant
    'Scent' is another if you want to go down the common consonants route, although maybe good for a second line, with the letter E completing the vowels and 10 different letters used.
    I’ve found that I’m getting the correct answer quicker if I follow the “Hard” setting of having to accept the clues.  Didn’t expect tgat
    I do it the hard setting way without having the setting on.
    I would imagine you would get better results as it forces you to think about your answer more!
  • TTonyTTony Frets: 27674
    That's the way I've always done it - seems easier not harder to me, but then I've been approaching it differently to some of the techniques described here.
    2-3-4-4-5
    (the 5 was the word that used one letter twice - that threw me!).
    Took 6 goes today (12th) but I nearly got caught out by the American spelling of the word, so beware!
  • the_jaffathe_jaffa Frets: 1808
    I failed because of the American spelling
  • MrTeeMrTee Frets: 511
    Stewards enquiry!!!
    I switched my 2 starting words today. Got it in 4. I figured it would be american spellings for applicable words
